least common denominator
Rib-eye
Out of the blue my wife bought a rib-eye, long story short is BBQ the best/only way to cook it? I ask because I have a cast iron griddle and the internet say it is okay to use that (and we know the internet is never wrong).
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
I would choose the cast griddle over a gas grill, but I would use charcoal over the griddle. JMHO
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Navin Johnson
How thick is it? that will determine how to cook it..
Do you have a sous vide wand? if not, and if its a thick cut, reverse sear us great season and sear in a skillet, and finish in a hot oven.. You can always cook it over charcoal... season, sear, then finish on indirect heat..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Another option, we just had some venison steaks that our 9 year old made. He preheated the griddle in the broiler and put the steaks on that once up to temp and they turned out pretty good with the seasoning on it.
It was his way of being safe.
I would not BBQ a rib eye. That's too nice of a piece of steak. I would use the cast iron skillet to sear it on both sides and eat it as hot as I can. Just salt it before you sear it. If you want, you can also pour a little butter into the pan as you sear it to get a really nice flavor.
MRM 1994 Carrera |
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100 |
Reverse sear is pretty hard to screw up.
If they are 1.5" thick cuts: S&P @ room temp. Then 30-40 min in (preheated) oven @ 250, (I usually put them directly on the grates with a drip pan/foil below). Then remove and sear each side for 30 sec. - 1 minute in a HOT cast iron skillet (use an oil with a high smoke-point). Let rest for a bit before cutting (can tent with foil). That should get you a nice mid-rare. YMMV... |
Navin Johnson
It really depends on how thick the steak is.. if its a 3/4-1" cut from a supermarket BBQ would be fine, even just a skillet, with no oven time.... If its a nice 1-1/2-2" cut of dry aged from a Butcher.. reverse sear, then oven finish, or sous vide if you have the equipment..You can BBQ(grill) it over charcoal, just finish it on the cool side of the grill This steak turned out epic. ![]()
)Edit: One minute per side correct?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. Last edited by scottmandue; 11-07-2018 at 02:36 PM.. |
You can also heat a cast iron pan in the oven at 475, pull it out and sear one side for 3-5 minutes, flip and place pan in oven for 5-7 minutes. Tent with foil and rest for 5 min.
Banned
Q
I BBQ everything and almost every day. I BBQ Rib Eyes a couple times a week, they seem to come out fine.
I would prefer to grill over bbq since the high heat creates the miallard reaction and I like them medium rare.
Navin Johnson
A NY strip I started souv vide, then finished in a ooni pizza oven that I got from kickstarter.. ![]()
To me, simpler is better in some things. This is one of them. My wife picked up an 18" cast iron griddle with a flat side from Aldi's, $14. I heated it smoking hot on the gas Weber grill, and put on the 2" ribeye on the flat side and seared it almost black, flipped it once and done. It didn't take long. Used a digital probe, got it to 135 degrees, it came out perfect.
I like em done on the BBQ and also cast iron skillet. If you get it right, both methods will deliver. The ribeye has a lot of marbling and will flare easily on the grill so you need to get the heat right.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
My wife & I usually split a small rib eye about an inch to inch & a quarter thick. We don't eat much steak anymore, maybe once every two weeks or so. I just heat a skillet to between 350 & 375, put some oil in the pan, and cook the steaks four minutes to a side & let it set for a few minutes. It gives me a steak with a crust and is medium rare inside. I don't put anything on them since my wife doesn't put salt on her food but just a sprinkle of salt on my piece before I eat it. Rib eye is the only kind of steak we buy anymore.
Marv Evans '69 911E |
The Stick
Have a Charbroil infra-red Smoker Roaster Grill. Put it on high and a mix of charcoal and hickory chips in the smoker bin. When it starts makng smoke put the rib-eye on the grill for 2 minutes per side twice to give it those crosshatched grill marks, Then let it set for 3 minutes in a covered pan with no heat and some butter on top... plate pouring the juice that has run out over the meat. Medium rare, delicious, and juicy.
For same results for thicker than an 1.5 inches, turn the heat to low after it starts smoking and put meat in the roaster for 3 minutes, then crank up to high and do same as above on grill for criss cross marks, cool covered, Really like this Smoker/Roaster/Grill, SRG. Can smoke meats for an hour and comes out just like it spent much much longer in a BBQ smoker. Did a turkey breast in the roaster part after coating with peanut oil. Was just like deep oil frying without the hassle of messing with the oil fryer. And because of the way it works, no flare ups.
Richard aka "The Stick" 06 Cayenne S Titanium Edition Last edited by RKDinOKC; 11-08-2018 at 01:31 AM.. |
Platinum Member
Anyone who has not, give souv vide a try. Especially if you like medium-rare.
Souv vide, then a quick sear. Tim, tell us more about the pizza oven.....
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
