Shaun @ Tru6's Avatar
Random welding tip
Making another dolly for a tub and the plastic lens on the outside of my helmet was in rough shape. That and don't use acetone to clean it. Had some 1/8" plate glass on hand so I cut a small pane out of it and and into the helmet. While you have to be a little more careful with the helmet, glass makes a huge difference in seeing over even brand new plastic. It was striking how much better I could see. Definitely worth the 10 minutes it took to make the glass lens.
Tru6 Restoration & Design
Old 11-21-2018, 03:06 PM
Here's another random welding tip!
Old 11-21-2018, 03:23 PM
clever!
Old 11-21-2018, 03:54 PM
Platinum Member
dad911's Avatar
Great welding. I've been trying to get one of these made, can you do it?
Old 11-21-2018, 04:12 PM
wdfifteen's Avatar
That’s one of Shaun’s, you can tell by his signature “S” on the top/bottom bar.
Old 11-21-2018, 04:16 PM
Arizona_928's Avatar
I have a pack of clear glass 2x4.25 for my hood. Put one on the inside and out. The inside is overkill.
dolor et pavor
Copyright
Old 11-21-2018, 08:37 PM
When I first looked at this it didn't seem right. Then I worked it out: not enough penetration in the top of the 45 degree weld, left of picture. Did you run out of Argon?
'72 911 T/E Silver Targa
Old 11-21-2018, 11:14 PM
