jyl jyl is online now
jyl's Avatar
How To Buff Stainless To Mirror
Hey, I need Pelican advice on buffing stainless steel (and other metals) to a mirror finish. This is for the espresso machine's exterior panels. They were originally mirror finished, I am trying to restore them.
I have a buffing machine ($69 Harbor Freight deal) and some 6" and 8" buffing wheels/pads. I have been using rouge to buff with. Sometimes it works great, and sometimes I get a cloudy haze. Is there a trick I am missing?
One of the pieces is quite scratched, up top where people must have been banging down cups and milk steaming pitchers for 20 years. What is the best way to get rid of the scratches before buffing?
Is there a role for hand polishing? I tried for a bit but it seemed like my hand would wear out before anything much happened.
Old 12-14-2018, 08:59 PM
Bill Douglas's Avatar
Autosol.
I used to polish my Triumph aluminum sidecovers to look like chrome.
It will work fine on stainless steel
Old 12-14-2018, 09:08 PM
The 9 Store
Mothers polish will get it back to mirror. I use my harbour freight buffer and ten finish by hand. Sanding is the only way to get rid of the scratches but it becomes a lot of work.
All used parts sold as is.
Old 12-14-2018, 09:15 PM
WPOZZZ's Avatar
Have you tried Gord's? It's awesome stuff!
Old 12-14-2018, 10:45 PM
madcorgi
Guest
Posts: n/a
I've had pretty good luck with successively finer grits of sandpaper on a DA sander, then jeweler's rouge. Here are some stainless pieces I needed a polished edge on, before and after. If you are getting cloudiness, I wonder if there was already some sort of finish on the steel. Clearcoat, perhaps?
Old 12-14-2018, 11:14 PM
I used the polishing kit available at Harbor Freight. I think it was about $20. Has several compounds and pads. I used a drill but you can use a buffer depending on your project.
With these I just went through the compounds. To remove the scratches wet sand first with 800, 1500, 2000 then polish. After you polish and clean with soap and water try polishing a little more with Never dull. The stuff is fantastic. Then apply a little wax
Old 12-15-2018, 04:14 AM
Old 12-15-2018, 04:20 AM
David's Avatar
I'm a big fan of Simichrome
SIMICHROMEPOLISH.COM
Old 12-15-2018, 05:32 AM
Recreational Mechanic
Nickshu's Avatar
Originally Posted by drcoastline View Post
I used the polishing kit available at Harbor Freight. I think it was about $20. Has several compounds and pads. I used a drill or buffer depending on your project.
With these I just went through the compounds. To remove the scratches wet sand first with 800, 1500, 2000 then polish. After you polish and clean with soap and water try polishing a little more with Never dull. The stuff is fantastic. Then boat with a little wax
When I did all the stainless trim on my Corvair during my restoration I used a Harbor Freight polishing lathe and compounds. Worked great. Messy business though. Don't wear any clothes that you like, and construct a large box that you can put the lathe inside, with an open end towards you. That keeps the mess down a little. The only thing I wish for on the HF was a lower speed, but it worked.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-15-2018, 08:24 AM
Evil Genius
Rusty Heap's Avatar
for multiple uses, i love my extended shaft 8" twin shaft buffer.
https://www.eastwood.com/eastwood-1-2-hp-buffmotor.html?SRCCODE=PLA00020&gclid=Cj0KCQiA6dLgBRDoARIsAJgoM4t7IlNMq-YRsCsHbchrzbU5qsmUNgQpOVhbl38uJrDMf9JKJjCE1_YaAqSV EALw_wcB
Life is a big ocean to swim in.
Wag more, bark less.
Old 12-15-2018, 05:38 PM
Zeke's Avatar
When purchasing buffing compounds in the stick form, you will find a few grades like 'jeweler's rouge'. One compound I have says for SS. I use a regular cotton buffing wheel. It seems all the products mentioned so far like Semichrome (good siht) do work very well but they can be expensive to be flinging it off a buffing wheel. I save those for hand work to put the last finish down.
Waxing or using a ceramic coating will really bring out the gloss, especially the ceramic.
Old 12-15-2018, 06:10 PM
908/930's Avatar
For the pieces that are quite scratched, depending how deep the scratches are, you will probably have to go down to 400 grit wet to cut them out, then move up to 600 wet, 800 wet and so on up to polish, probably want to use a rubber sanding block also to help keep it flat.
No harm in hitting it with polish first and see if they will blend in.
Old 12-15-2018, 07:07 PM
I use Renaissance wax. I learnt about it on the S&W site. It makes blued guns quite titerally glow. It was originally developed by the British muesum for protecting statues outdoors and other artifacts indoors, but works well to make things shine like SS.
Old 12-15-2018, 08:03 PM
Brew Master
cabmandone's Avatar
One more here for Jewelers rouge. I used it for the petals and lips on my Fuchs.
Nick
Old 12-16-2018, 05:10 AM
jyl's Avatar
I'm frustrated. My buffing wheel loaded with rouge just put a bunch of fine scratches in part of the panel. I guess I'll get new wheels and start over.
Old 12-16-2018, 01:35 PM
I have had better success with Eastwood products.
Old 12-16-2018, 01:54 PM
Brew Master
cabmandone's Avatar
Are you sure they are scratches and not burns? I thought mine was scratching and it ended up being rouge that got too warm. The other thing is, are you getting it down to a fine sandpaper prior to buffing?
Nick
Old 12-16-2018, 05:14 PM
For a world class shine you have to go through multiple steps of sanding. Then multiple steps of polishing.
Old 12-16-2018, 05:33 PM
jyl's Avatar
The fking surface was originally mirror polished, just light scratching from decades of use. Now I've made it worse. Pissed. Stepping away from the buffing wheel for awhile.
Old 12-16-2018, 09:57 PM
https://www.facebook.com/1270631299/posts/10212583164795336/
Old 12-17-2018, 09:26 PM
