Perpetual Reassembler
2jmotorsports's Avatar
Bang 4 Buck Engine to Learn Engine Building & Tuning
What is your recommendation for a bang for the buck, easy to build, fairly robust engine with good parts availability where one could experiment with all aspects of engine building and tuning? Bottom end, top end, different induction and ignition methods, blueprinting, balancing, etc. etc. etc.
Something that responds well to mods and is easy to rebuild if it blows up to continue the learning process. My guess is a 4 cylinder would be a good starting point simply because they have very cylinders (and less parts to assemble) and are available in so many different cars. Open to all years. The chassis might be whatever the engine came in or might be swapped into a more appropriate "test bed". Location is California, U.S. so a pre-smog test vehicle might be key here. Lets assume I have basic engine building skills and access to decent machine shop services as needed.
This engine would be merely a teaching tool. Not expecting to build a mythical high horsepower, reliable motor for no money.
Someone has already recommended a Ford Lima 2.3. There are probably a few Honda or Toyota candidates as well that might work.
Thanks in advance for helping this student for life.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 02-21-2019, 12:46 PM
Small block chevy is as cheap as it gets. Go get a mid/late 70s GM or something.
Brent
Old 02-21-2019, 12:53 PM
Banned
ford pinto 4 banger is used by oval small classes so lots of parts and cheap
turbo the Nissan 6 det- series as used in the skylines
honda has lots of aftermarket goodies but not as cheap as pinto stuff or pre-smog
Old 02-21-2019, 01:23 PM
maybe later find an old air cooled VW engine. easy to rebuild and it would give you some experience with a clam shell case. I had a lot of fun rebuilding my 914 engine.
but yes I agree with the others small block chevy is a great project. you can sell it and fund the next build. Post pics as you go so we can see your progress. That would be a cool thread to follow. tear down to machine shop to rebuild and running.
Old 02-21-2019, 01:42 PM
Arizona_928's Avatar
-03 kubota diesel 4 cyl engines.
dolor et pavor
Copyright
Old 02-21-2019, 02:29 PM
Lots of snow Porsche away
350 chev is the obvious choice.
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 02-21-2019, 02:47 PM
LWJ LWJ is online now
I got an old continental tractor engine in my garage. Parts seem almost free.
Old 02-21-2019, 04:36 PM
+1. Simple and inexpensive.
Old 02-21-2019, 04:40 PM
Small block Chevy. Super cheap and parts everywhere.
Old 02-21-2019, 04:43 PM
Cali, I think a Honda B16/18 might be a very fun cost effective engine, or maybe the K20/24 to drop into a Miata...
The Chevy is a cheap lump as well, I also love the good ol Ford 302.
Old 02-21-2019, 05:32 PM
Small block Chevy or bug engine. Both can be built with minimal tools and cheap parts. Get a bug motor and the Idiots guide to bug maintenance.
Old 02-21-2019, 05:39 PM
VW or smalll block Chevy.
Old 02-21-2019, 05:57 PM
chapo's Avatar
Try a VW , cheap easy, and even if you do it wrong they usually run for a while lol
Patrick
Old 02-21-2019, 06:53 PM
Awesome. Thanks for the suggestions. Never considered tractor motors so Ill spend some time researching those as well! Keep em coming!
For the record I am wrapping up a rebuild of my 83 SC CIS motor but thats a very "follow the recipe" kind of a build so I dont screw it up. Its too expensive to experiment with those lumps!
Old 02-21-2019, 08:32 PM
Bland
unclebilly's Avatar
I dunno about the SBC these days. That was the low cost engine to build 30 years ago and there was huge aftermarket support, etc.
These days I think the modern Chevy LS is the more cost effective, simp,e way to go.these engines are one a dozen too. Look for a 6.0 with Aluminum heads as a good starting point. A cam and a few other low cost items and you are at 500 HP for under $1000, maybe under $750.
Old 02-21-2019, 10:23 PM
DanielDudley's Avatar
Miata engines come with an entire car. They are cheap and easy to build, and have a huge aftermarket following. You won't get easy gains with a simple exhaust and intake though. The engine is a little gem, and the car is fun to drive. They are tough, and can take boost.
I have built a number of engines over the years. Proper machine work, cleanliness, and attention to details and tolerances apply to all builds. Different engines though have different tips, tricks, and techniques that have to be employed, and different mods to extract performance. I build engines to put in cars and run. Starting them up is a thrill, and I enjoy breaking them in and running them out. I blew up a couple of engines before I learned how to build a proper engine, but I was a kid, and information wasn't as easy to come by in those days. In some ways I learned more from my failures than I did with my successes, but there is never an end to learning.
The only way you can really find out how good your engine is is by running the heck out of it. That is the part that makes all the rest worthwhile to me. Miatas are good hobby cars for that, and people do throw V8s in them or boost them for higher power. If you want the experience of building cars or engines, this is the shallow end of the pool. Otherwise, I would advise you to pick the car you are interested in, and work on those. If you choose complicated engines, use the buddy system. However, a Fiat X1/9 engine is essentially half of a Ferrari 308, and somewhat similar to a Miata, a 928, or 944. A VW bug engine OTOH, is a lot like an air cooled 911. And like the Fiat is to the Ferrari, there is a commonality of layout between a beetle and a 911. If you can pull a beetle engine and tear it down, you will feel at home tearing into a 911. If you have built a Miata or a 944, you are a step away from a 928 or a 951.
Where do you see this progressing ? Think about that before you choose. A lot of people are really happy building 10 second Fox body Mustangs. Others are not. I happen to love Miatas about as much as any car I have ever owned, and they are one of my top 5 cars. To other people, they will always have a stigma. Like art, you should collect what you like.
Old 02-22-2019, 03:03 AM
Brew Master
cabmandone's Avatar
I'm gonna be the nut that suggests a go kart with a Lifan 420 or Predator 420 engine. You can tune the hell out of these things and the mods are cheap. I think you can get fuel injection systems for these engines or play around with a carb. You can even find a turbo for these things!
I could be way off base here but if you want something that is highly modifiable, tunable and cheap, a single cylinder or even some of the twins would seem to be an obvious choice.
Nick
Old 02-22-2019, 05:20 AM
Still Doin Time
asphaltgambler's Avatar
My opinion / experience. Early 70's SBC 350 as the machining was poor ( but average for the time) and the castings were better ( quality ). If your goal is teaching / experimenting with increasing HP/TQ - start with the short block, observe how far down into the bore the pistons top out, rough castings, uneven wear on main and rod bearings.
The first step in any performance build is 'blue- printing' the block, deck height, align boring main / cam journals, etc. Also how much power ( and type) will a 2 bolt main hold? How much power will the stock rods hold? How can you gain power by greatly reducing rotating assy friction? How can you move peak TQ /HP by changing rod length ( there are a couple different stock lengths.
How about reducing rotating mass / weight for faster engine RPM acceleration?
There is so much to be gained in performance and learning / basic engineering principles in just the short block. If you have access to a really good machinist this is where to start.
Every good engine starts with a great short block foundation.
Old 02-22-2019, 05:45 AM
This is a tempting choice because of 2 reasons. 1) Seat time in a fun to drive car to test the engines is important to me 2) I work at Mazda and have access to parts and Miata gurus.
Yes! This! I feel like there is a list of general engine building best practices that apply to all platforms like some of what you just mentioned. These are the kinds of abilities I want to develop so that I can spot trouble or areas of improvement no matter what engine I tear into. Maybe even get to the point where if I am building my own spec racing engine (of whatever kind) I know what little details I can do that will give me an edge and still let me stay within the rule book.
Thankfully there are quite a few engine machine shops in my area. Additionally my 70 year old dad is retiring soon and is a phenomenal machinist, although not the automotive kind. He is super sharp and Id like to help keep his mind occupied as we both learn how to blueprint engine internals.
I have all these great ingredients surrounding me and I just need to pull them together to be able to build cool machines.
Old 02-22-2019, 08:17 AM
Hmm...karting...like F1 drivers...this is also a tempting option.
Old 02-22-2019, 08:28 AM
