The Fed...I was not correct....
Tabby was right, fint was right, as a fiscal conservative....I was wrong . I have been 100% behind what the Fed has been doing with ultra-low interest rates to banks, and STARTING to make a dent in the 4.5T they "borrowed" to fix the aftermath of '08/09. But they indeed have done a 180 turn due to the recent data...and now 4T will remain on their balance sheet forever? That's BSheet imo. Discuss...
Old 02-23-2019, 04:05 AM
Preferred pronoun:Maestro
Norm K's Avatar
G. Edward Griffin was right.
_
When in doubt, use overwhelming force.
Old 02-23-2019, 06:14 AM
Send a message via AIM to fintstone
Raising debt by artificially keeping the interest rates near zero for 8 years was no more a good idea than raising too much, too fast to try to "pay it back". In both cases, the wrong people have to share too much of the load too fast...which damages one part of the fragile economy at the expense of another...ultimately creating more debt than you gain by the higher or lower rates. The Fed just miscalculated and got a little ahead of itself. "Borrowing" to give money to one group of taxpayers...and later expecting to get the money back from another group...or even the same group is simply too much intervention Wealth redistribution never works like the folks doing it expect. Raising rates is much like raising the rents in your rental. Even if you are below market, if you raise them too fast, expect your tenants to go elsewhere (even if they are still getting a great deal). The month that you go unrented to get the extra $100 on the $1000 rent will take wear or more to recoup (or worse as you usually have marketing costs).
The increase was so much so fast that people were starting to lose homes in droves again to foreclosure in some areas.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-23-2019, 07:22 AM
I respectfully disagree....I am not alone...time to realize that 2% (unstimulated GDP) is the normal....and continue the recovery out....
It has been hosed .... if they keep 4T on their balance sheet forever as I just read...
Tabby?
Old 02-23-2019, 07:47 AM
Originally Posted by fintstone View Post
Raising debt by artificially keeping the interest rates near zero for 8 years was no more a good idea than raising too much, too fast to try to "pay it back". ....
The rates should have risen much sooner, and faster after the housing debacle....
Low interest, variable APR has allowed another credit driven mess....5 yr furniture, 7 yr auto, ...
We're not even back to "neutral" on rates...and that 4T BS forever is just that .
Old 02-23-2019, 07:55 AM
That was my point. You cant fix 6 years of juicing the economy to mask/make up for an anti-business Federal policy in a single year. The impact is too great. Especially on folk too young or too stupid to remember the past or recognize it for what it is.
A good example is a rental property I own. It has an adjustable mortgage that has increased about 2 percent. In addition, HOA, taxes and insurance also increased dramatically (catch up after the real estate crash). I was already losing well over $1k per month (ignoring increase in equity due to increase value and paying down mortgage). Now, it is almost $2K. While I can afford to lose $2K per month, other folks in the same neighborhood cannot. It has started a wave of foreclosures. Some were family homes and others were rentals like mine (that will leave the rental market forever reducing the number of low cost rentals). Of course, it will eventually drive the rental income of mine up due to lack of competition...but it also creates a glut that keeps other homes underwater (zombie foreclosures Tabby talks about) and keeps first time buyers out of the market. It also means that a lot of other things bought on time went up very fast (cars, appliances, etc.)...preventing the people with those loans from buying other stuff. Small amounts are tolerable and people make adjustments. Rapid increases, not so much.
Old 02-23-2019, 08:26 AM
You have your perspective, I have mine.
The "juice is still on" however....the Fed began a well laid out strategy back in '15... of raising rates...pretty consistent 2.5 gdp...good enough for some . Anybody hitched to the past...your risks, your problem. Easy, cheap credit ain't the answer....we're ten years in....how long does it take your way? Caused the Fed has turned on a dime....now what...pass it on forever....
4T on the Fed's balance sheet? You think that should continue to unwind....I sure do.
Old 02-23-2019, 09:14 AM
Actually cheap credit is the problem. 8 years of it. But it is like crack. You cant give it away for 8 years and then stop...telling the addicted that they should just suck on a life saver and start running 5 miles a day to atone/fix their body.
With respect to my example, 2015 is recent. My loan in the example (like may others) is from 2006 where the home lost 65% of its value...and the home is still worth more than $100K less than the home cost. While losing a few thousand a month is chump change for me...it may not be for others. The rapid increases were too much for small businesses and small investors. The economy was showing signs of too much increase in rates too fast (both in the job market and the stock market). Too much was spent and too long was wasted. You cannot make up for 8 years in one or two.
Maybe the mistake was giving away all that money to start with...and asking others to pay for it now.
Old 02-23-2019, 11:04 AM
Start yer own damn thread about the still historically low Fed interest rates....are you dense? I'm outta this one....
What do you think leaving of leaving 4T on the Fed's BSheet permanently...as every post I've made has asked and that's what this thread is ALL about...now...I hope .
Anyone else ?
Old 02-23-2019, 12:05 PM
I'm sorry...I thought that was what we were talking about. I guess I don't understand the question. How would you suggest we take the $4T off of the Fed's BSheet without increasing short term rates? Magic?
They are tied together (interest rates and Fed Balance sheet). As you rapidly reduce the Fed BSheet, you also rapidly reduce liquidity because banks have used those funds (bonds sold to Treasury) to meet stricter, post-recession reserve requirements (banks have less ability to lend). If you reduce liquidity...businesses cannot borrow to grow/expand and interest rates creep upwards (demand). Of course it should eventually be unwound a bit..maybe as far a the approx. $1T before the bank crisis, just not so fast. The resulting increase in short term rates would be very hard on the economy. The 4T is less dangerous that fixing it too fast. Just the .5T or so already drained had begun to have an impact (I was referring to earlier).
Old 02-23-2019, 02:18 PM
jyl jyl is online now
jyl's Avatar
I'm not sure what the right size for the Fed's balance sheet is. I've read that the amount of money has grown greatly so the Fed's balance sheet can be larger than it used to be.
I'm also not sure that it makes a difference where the bs stabilizes. If the Fed buys $1 of a newly issued Treasury or agency bond, while at the same time collecting $1 of principal as an older bond matures, nothing really changes. No additional money is pumped into or removed from the economy.
In other words, it is the change in the Fed bs size, not the size of the bs, that really matters.
(Within limits, which we're probably not near.)
What's the right level for rates? I don't know how to decide that except by looking at the effect of rates.
Rates so low that they encourage people and companies (and governments) to accumulate excess debt burdens are too low. Rates so low that they encourage diverting capital to paper assets (stocks) and debt-dependent activities (m&a, share buybacks) instead of to productive investment (capex, hiring, growth) are too low. Rates so low that the yield curve inverts (which makes banks stop lending, since deposits cost them more than loans generate) are too low. Rates so low that people who should be in low risk investments (savers) are forced to chase risky investments (become speculators) are too low.
I think we've seen some of those conditions.
Rates so high...you can fill in the list.
I don't think we've seen much of that, except for a brief 20% drop in stock prices (investor tantrum). That's not nothing, of course, but bull markets have to end sometime.
Old 02-23-2019, 03:31 PM
A Man of Wealth and Taste
tabs's Avatar
Some people don't get that if the FED didn't juice the system with massive liquidity you would all be living in mud huts. What don't you get when they said "meltdown?"
The FED isn't in control of anything...they are forced to keep juicing the economy. If they reverse policy Equities fall of a cliff..as you saw in December.
The question is how long can they keep on juicing and the govt borrowing before the house of cards all falls down.
Old 02-24-2019, 01:45 AM
tabs's Avatar
Tantrum??? That's a dumb thing to think. The bottom line is that the WS Boyz understand that without the FED having an accomodative policy the economy falls off a cliff.. and they get real nervous and want out..the system now only works with juicing and deficit spending...
Both u and the other articulators of opinion bend over and take it like a woman.
Old 02-24-2019, 02:19 AM
tabs's Avatar
The FED is only reacting to extingencies..
You folks think they are in control of events? Your denial makes you delusional...cray cray...December should have proven to you that reality by their reversal of policy. The bottom line is that you continue to deny is that the American consumer is tapped out and the global economy is not sustainable.
Old 02-24-2019, 02:39 AM
tabs's Avatar
Weasel weasel dodge and obstruftication will do you no good as you continue to twist in the face of reality.
Old 02-24-2019, 02:50 AM
You folks think they are in control of events? Your denial makes you delusional...cray cray...December should have proven to you that reality by their reversal of policy. ....
Everything was going along very well with the early stages of the Fed reducing their balance sheet imo....while continuing to get the still ultra low rates back to normal. It's a HUGE task...they were able to jack them up much rapidly just a few years earlier...after 9/11....but in unknown territory....they couldn't raise rates from 0, when stimuli like the QE that ended in '13 (I think) was buying (borrowing) ...then '14 produced a couple of high gdp qtrs....deflation was over....time to dig out. So they began....
Early Dec, "I'm a tariff man" tweeted/spoke, and the markets immediately dropped like a rock...past long overdue correction territory...
Then the Fed turned from what I considered a very fiscally conservative, but somewhat aggressive "payback"..... it WAS working except for those hitched to historically low variable interest rates. The conservative in me says....(within reason)...I don't care...live within your means and don't depend on cheap credit...it's the opium of our society....worse than ever.
fint's a credit junkie
When I read that the Fed was NEVER gonna reduce their 4T bs ANYMORE, at all....ever. Well....they caved to a correction in the still juiced equity markets...I'm a tariff man spoke and here we are
Just scratching my head....fint, will you loan me a few T....I'll pay ya back....I promise...my credit's good
Old 02-24-2019, 03:39 AM
Brew Master
cabmandone's Avatar
Let's be honest, the fed screwed the pooch long ago as did our federal government before, during and after the financial collapse. As tabs has stated repeatedly and correctly the American consumer drives the economy. Rising interest rates were having a negative influence on consumer spending. Still say the December numbers have to be revised upwards
A lot of noise has been made about GM and Ford sales and the hurt it's putting on them. How do we fix it? Keep rates low and let that bubble grow brother! Get ready for another round of bailouts , it's coming.
Nick
Old 02-24-2019, 05:24 AM
Actually, stupidity by the Administration with the massive bailout of bad loans (HARP, etc.) and pushing short sales which were massively fraudulent drove the property values so low in some places that there was no exit. Particularly with strategic foreclosures and bankruptcies. Those of us that paid our bills and didn't borrow from the government were screwed. Although I did buy the house with a conventional adjustable rate mortgage, I did so temporarily so I could close quickly. I fully intended to refinance into a VA or conventional fixed rate in a few months. Then the market crashed and I really had no viable way to refinance as the $700K home was valued at $280K. I would have had to bring $400K to closing as a down payment on a $280K house. Considering all my other investments also crashed...and both my wife and I lost our "secure govt jobs" at the same time...it really was not an option.
While I have fully recovered and then some...I am still paying on that mortgage (hose is worth about $500K now). It is not a problem for me to waste a few thousand a month...but apparently it is for other folks (as the foreclosures are ramping up again). I thought my example was pretty clear that was the case.
Old 02-24-2019, 09:14 AM
tabs's Avatar
Your time line is off, and it makes your conclusions off as well.
QE3 was announced in 9/12, where Equities were off to the races, Bullard said on CNBC on 2/23/13 that they would Taper Off finally announcing the Taper after a FED meeting several months later. Finally ceasing QEing in 12/14. After the end of QEing in 12/14 Equities remained more or less flat until Trump won in 11/16.
In 12/17 they started taking 50B a month out of the economy to reduce their balance sheet. In 2/18 Powell took over from Yellsin announcing that the FED would go to a NEUTRAL policy while raising interest rates The first big break in Equities came in February of 18...recovering to new highs in September 18...
With a continued hard line in the face of a projected softer economy Equites broke and ran in 12/18...ONLY TO MAKE A TURN ABOUT ON 12/26/18 AFTER THE FED MADE CONCILIATORY COMMENTS ABOUT POLICY (starting on 12/21/18 with the Pres of the NY FED)>>.
It is not a matter of being addicted to low interest rates...the low rates are a necessity especially since the US is encumbered with so much debt that needs to be serviced. The US is borrowing money to pay the electric bills. Is that simple enough for you to understand..Without deficit spending the economy does not generate enough of revenue to keep the economy afloat. The American consumer is a spent force...
The global economy needs financially healthy consumers to buy the crap that they make...if the consumers do not buy the economy tanks...
Copyright
"Some Observer"
Old 02-24-2019, 01:33 PM
tabs's Avatar
So the FED has announced that they are gona keep the balance sheet at 4T or there abouts...FOREVER?
Some surprise that is...NOT!
The problem with the FED just like you boyz is...they think/thought it can be fixed, that there is a solution..if only they find it...so they have tried this and that...all to get back to what was the old normality...None of it has worked...and now they are admitting with the Forever statement that there is nothing that they can do...
I told you long ago that when the leadership cant remedy a situation new leadership is found and when that fails despair sets in...and that the same thing is true that when you try all the tricks in the book and nothing works...you realize it can't be fixed...and despair sets in and a acceptance of your fate.
The FED to have made that statement must have seen something very mushy in the data about the economy..That to maintain stasis in the economy they can not rock the boat..
The question becomes by maintaining their balance sheet does it cause dislocations throughout the world? In other words how long can they keep the music playing before it stops..
Copyright
"Some Observer"
Old 02-24-2019, 01:49 PM
