Mercedes M275 Engine
I'm a collector. Something tells me I should have one of these sitting in my garage under a blanket. They're cheap, like LSx cheap. Am I nuts? I wonder if one would fit in an E36.
Discuss.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Control Group
I don't know, that turbo looks a little smallish
She was the kindest person I ever met |
Team California
That's why there are two of them.
Denis |
small turbo = quicker spool.
wiki says 500 hp, 600 ft/lbs trq. Bigger turbos will prolly get 100+ hp out of it. The LSX 454 is 600-ish hp N/A. However, also 12 grand. For 3 grand on a M275... that's a lot of bang for buck. Gut the accessory drives on it, adapter plate for transmission combo, and tune the ecm to run stand-alone. Would prolly be at half the price of the lsx 454.
dolor et pavor Copyright |
AutoBahned
it would kick ass in one of the little Fiat mini-cars
beancounter
I'm thinking there is much less aftermarket support for the MB engine vs. LSx variants.
Have read a number of threads on the topic of swapping MB diesel engines into other chassis, and one issue I've seen is that the engine ECU needs to handshake with other components (like the dashboard and transmission control units) in order to run. While anything is feasible, I'd imagine a whole lot of engineering is required.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
maybe drop in a 240z?
81 sc 3.0 turbo wb coupe |
Bland
It will be under $3000 to get 600HP out of a LSx. I’m sure it could be done for under $2000.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Ticking time bomb that is. You can take a 5.3 and install stiffer springs so you don't float valves, corvette cam, and bubba junkyard turbo it. That'll net 500 + hp. I've built one, and they pop. My 928 has seen more engines than a tug shop in Florida. Well maybe not that many, but after the fourth I'm convinced on the lsx376 will be the next one.
White and Nerdy
White and Nerdy
Still Doin Time
I dig it, think it would be a great swap into anything. Pretty sure you'll need the body control module as the ECM will need to see the security system disabled, recognizing the ignition key / chip.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
beancounter
White and Nerdy
Work in Progress
Think we could stuff one of those in this?
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Stahlwerks.com
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
beancounter
I’d prefer that ride with a diesel.
This G wagon isn’t diesel, but it is bulletproof...maybe a better candidate for the OP’s engine https://newyork.craigslist.org/mnh/cto/d/palmer-1984-mercedes-benz-class/6822184587.html Last edited by jwasbury; 03-07-2019 at 08:31 PM.. |
Yes Nuts Apparently Time bombs https://youtu.be/Rlj7254gOww
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Did you get the memo?
That’s pretty awesome but unless you are a stud with standalone engine management it would be a nightmare to get running correctly, not to mention interfacing with the rest of the car.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Cars & Coffee Killer
Stuff it in the back of a Cayman...
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
