id10t's Avatar
Generator gas...
So after Friday's pre-season demo and running my generator...
Do I drain and pickle like at the end of Hurricane season?
I'm expecting to need it again in the next 6 months... or not at all.
Leave the gas that is in it, add some Sta-Bil or SeaFoam and then drain and pickle at end of 'cane season?
Something else?
Thanks! Was nice having it start on the first pull when I needed it...
Old 04-22-2019, 08:17 AM
Deschodt's Avatar
I'm sure experts will tell you... Personally I sta-bil what's left and let it run dry if there isn't much left. Or leave it with stabil but also run it a bit so it's all over the carb and lines for sure. I got tired of cleaning the carb/lines... If possible, I loan it to all my camping friends so it gets run several times a year.
Stabil really work - last time I did not use it, whatever came our didn't even smell like gas and it caused the mother of all cleanups..
Old 04-22-2019, 08:24 AM
expatriot98's Avatar
Run it dry
Old 04-22-2019, 10:43 AM
I shut the fuel line off and let her run till she dies and put stabil in the tank. Owned her for 15 years.
Used it twice.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 04-22-2019, 10:57 AM
I'm with Bill
Jims5543's Avatar
I have an old gas generator that I have had since the 90's and still runs great and never a carb issue.
Another +1 on run it dry, I take it a step further, after it runs dry and cools down, drop the float bowl down, empty it and dry it out. Leave it off for a few let any residue evaporate.
Reassemble and store it away. I give mine an oil change before storing it.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 04-22-2019, 11:23 AM
Registered ConfUser
All the above but about once a quarter I start it and let it run for 10 minutes. Shut off fuel valve and run it out of gas and put her away.
Mike
Old 04-22-2019, 11:28 AM
rfuerst911sc's Avatar
Put Sta-bil or the brand of your choice fuel conditioner in the tank . Start the generator and run it for 10 - 15 minutes you are trying to make sure the fuel conditioned gas is fully in the carb . Then turn the fuel shutoff off and let it run until it quits . This gets rid of 95 % + of the fuel in the carb and what little is left over has the stabilizer in it . Start the generator every 3 months but go through the above shut down process . I doubt you will ever have a carb issue going this route .
Old 04-22-2019, 11:32 AM
Ethanol gas...run it dry. Otherwise Stabil....jmho.
Old 04-22-2019, 06:01 PM
carreradpt's Avatar
Living in hurricane country, I break out the generator and run it once a year. Always with non-ethanol and run it for a while with/wo loads until it runs dry. I don't keep much gas around but it is always with sta-bil. Always a one pull start.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 04-23-2019, 10:47 AM
I would run it dry on some two stroke mix. Works on my snowblower.
Old 04-23-2019, 10:51 AM
