rfuerst911sc's Avatar
Convert soda machine to gun safe ?
Was surfing local CL and I always check for gun safes . I have one safe already but like many folks it is crammed to the max ! I see some Coke/Pepsi machines being sold for reasonable prices .
Many have already been stripped of the compressor and related plumbing . Any of you guys converted a soda machine to a gun safe ? Is it just a matter of re-doing the interior ? I assume because of insulation they would stay dry inside with some desiccant ?
Old 05-24-2019, 03:20 AM
Bland
unclebilly's Avatar
That’s a cool idea. I was thinking of using an old filing cabinet... thieves would never look inside it or suspect anything if it was locked.
Old 05-24-2019, 03:50 AM
I think the primary reason that most people get a heavy duty gun safe is for fire protection, and virtually crime proof because of it's weight, and inpenetrable walls. This might not be the case with a lightweight soda machine that could be breached easily.
It would be more like a gun cabinet for storage.
Old 05-24-2019, 04:10 AM
Most gun safes are made with a thin metal exterior skin , then fireproof layer and then interior carpet . Some are made better than others and the cost reflects that . However they are not as in penetrable as many think .
And some are like a bank vault . I am thinking take a soda machine , strip the interior and cover with sheetrock and carpet . So you have metal exterior skin , factory insulation , factory interior metal skin then DIY sheetrock and then carpet . That should be a decent deterrent and fire rating . Bolt the machine to the floor and wall it's not going anywhere .
Old 05-24-2019, 04:26 AM
Cool idea...make it happen
.....with pics!
Old 05-24-2019, 04:32 AM
Platinum Member
dad911's Avatar
My first thoughts:
Wood is rated for 1hr per 1.5". I'd make an inside box of double 3/4 ply, or try to find some solid core wood doors on craigslist. Line it with carpet, and spray fire rated foam insulation (the red stuff) around the outside of the box.
Old 05-24-2019, 04:48 AM
MBAtarga's Avatar
Instead of sheetrock - use backerboard (Durock) - which has additional fire resistance. The additional weight will be a benefit and you can still just glue/screw carpet onto it.
Mark
'83 SC Targa - since 5/5/2001
Old 05-24-2019, 05:25 AM
A Man of Wealth and Taste
tabs's Avatar
Sawzall right across the top, then a pry bar to peak it back like a sardine can. Then it is look ma what I found in here.
Old 05-24-2019, 06:47 AM
tabs's Avatar
Stands to reason you spend accordingly to the value of what you have to protect..
Old 05-24-2019, 06:52 AM
Slackerous Maximus
HardDrive's Avatar
Better idea: Find a commercially made gun safe that would fit inside the soda machine. Empty the soda machine of contents, and retrofit the safe inside. You get the protection and the style.
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 05-24-2019, 06:54 AM
Yep and the same can be said about many commercial gun safes for sale. I have a Field and Stream branded gun safe I purchased from a sporting goods store. It looks nice , door sounds impressive when you close it . I could probably cut my way into with an axe in a few minutes . In my opinion any gun safe under 2K is probably built too light .
Old 05-24-2019, 06:56 AM
Control Group
Tobra's Avatar
What sort of dummy is going to cut the top off a soda machine with a sawzall to get all that delicious Dr Pepper?
You can even put a little electric motor in it so it sounds like it is running, and blinky out of soda lights so if the crook won't get suspicious if they get thirsty when they break in.
Old 05-24-2019, 07:25 AM
Slackerous Maximus
HardDrive's Avatar
Love the idea btw.
2014 Cayman S, PDK.
Old 05-24-2019, 07:47 AM
vash's Avatar
I think the benefits would be to hide the safe. Theory would be nobody would give your soda machine a second look while rummaging for firearms. Right?
Old 05-24-2019, 07:58 AM
Zeke's Avatar
IDK about GA but here any soda machine worth taking home and looking at is gonna cost 4 figures and up. Saw a Vendo 18 fully restored yesterday for $6500. They told me a lot of Japanese come here and pick these things up. So they aren't shy on the selling prices.
Old 05-24-2019, 08:07 AM
Control Group
Tobra's Avatar
He is probably not thinking nifty vintage machine Milt. They would steal something as cool looking as that thing
Old 05-24-2019, 08:08 AM
Driver
Noah930's Avatar
What if the thief gets thirsty?
1990 Black 964 C2 Targa
Old 05-24-2019, 08:37 AM
Keep your pop guns in there.
206 637 4071
Old 05-24-2019, 08:45 AM
NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
^ that’s pretty funny right there.
Blew soda all over my keyboard.
Old 05-24-2019, 08:48 AM
vash's Avatar
Oh we have jokes? Haha
Old 05-24-2019, 09:02 AM
