Dishwasher machine tip.
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness Last edited by SoCalSK8r; 05-30-2019 at 01:24 PM.. |
In Vino Veritas
Two types of dishwashers for both commercial and residential fitment. One sanitizes with hot water, the other utilizes chemicals. Keeping the filter clean is also always a good idea.
Todd '85 3.2 Targa/'87 951/'04 C4S Coupe "Nothing Ventured, Nothing Gained" Thomas E. |
You do not have permissi
Don't forget the pull-out filter at the bottom.
Label glue and various effluence will clog that puppy up. A primed/clean pump is a happy pump! (add an extra tall glass of piping hot water over the liquid detergent just to be sure, and make sure the first cycle is on 'fill'.) Also remove the spinners and make sure they are also not clogged at the ends and the O-ring is still valid. Also check and gently clean off those door seals once in a while. Last edited by john70t; 05-30-2019 at 04:12 PM.. |
The 9 Store
Most dishwashers connect to the cold water line. So running hot water beforehand just wastes hot water. Look under the sink and check.
All used parts sold as is. |
UnRegistered User
Most domestic dishwashers call for a minimum of 120 deg F for supply water.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
canna change law physics
My BOSCH dishwasher heats the water. But it uses electricity whereas my regular hot water is gas/solar. So yes, run the faucet to get the water hot first.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Not any I have owned
A Man of Wealth and Taste
What ever detergent I am using dissolves my plates...and leaves a mess at the bottom of the dishwasher...
Copyright "Some Observer" |
Information Junky
Also, by using self heating appliances the thermostat on the HW tank/heater can be turned down, giving even more power savings.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
