T77911S's Avatar
metal pipe?
why a tracer wire.
also a bit heavy ga for tracer
wrong color for ground wire..
I have tracer wire on some fiber at work, much smaller if I remember correctly
not saying its not tracer,
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-10-2019, 05:35 AM
MBAtarga's Avatar
Originally Posted by T77911S View Post
metal pipe?
why a tracer wire.
There is a transition under ground from metal to plastic. The tracer wire is used so the utility location service can tie their transmitter onto the wire and "trace" the location of the plastic pipe underground to mark the area so as contractors, etc will hopefully avoid the area when digging or boring with any equipment.
Mark
'83 SC Targa - since 5/5/2001
Old 06-10-2019, 06:19 AM
T77911S's Avatar
yes, I know what a tracer wire is.
I have fiber that I have to locate for work using a tracer.
that tracer seems kind of thick, most companies want to go cheap and put in a thinner ga wire.
are you sure it transitions to plastic. they may want it metal so local home owners cant break it to easily.
did not know it transitioned to plastic.
RACE CAR:: sold
Old 06-10-2019, 07:02 AM
chapo's Avatar
It’s a tracer wire installed by the plumber and required by code. It is what Dig Alert or any other underground utility located uses to find the plastic, yes plastic, gas lines underground. This is not a mystery or conspiracy, read the plumbing code or call the utility company. The size of wire is dictated by code.
Patrick
Old 06-10-2019, 08:43 AM
T77911S's Avatar
ok.
just seemed a bit odd if it was metal pipe all the way.
RACE CAR:: sold
Old 06-10-2019, 09:55 AM
Wildman Emeritus
Answers a question I have had since gas line replacement. The knowledge here.........
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 06-11-2019, 06:35 AM
