On most street vehicles, a pound or two in either direction doesn't matter but consistency L/R on each axle is always important.
https://www.consumerreports.org/cro/tire-pressure-gauges/buying-guide/index.htm |
Ah. Rubbin's racin'. And racin' guys spend I would hope more than $70 on a tire gauge. It seems to me if you're going for tenths of a pound, then you are limiting yourself right off the bat to digital pressure gauges that have been tested. I mean it would seem logical to not reach for the old school free O'Reily's stick tire gauge and then be disappointed/ shocked.
Just tested 3 of mine. I was not pleased with the results, but like many here have said, a man with more than one is never sure....
Maybe I should buy another, so I can become confused?
http://forums.pelicanparts.com/uploa...1561233907.jpg |
To reiterate,-
I was quite shocked and surprised as my old stand-by which was over 30 bucks back in the day and the other five gauges could find no agreement. None. It may, in fact, be right..but compared to what when I get the new gauge? Will I now have seven gauges that have dysentery derivative dysfunctional psychopathic skill set? (sort of like those that came up here from the bowls to add their two cents of drool) There seems to be just no way of calibrating without a 5000.00 dollar machine. Something so simple sometimes just is not. If I could find three or four that read close to the same perhaps they would be right...but that is just betting on an average and not a sure thing. |
Yeah, it certainly doesn't seem like an easy thing to fix if you want to get something calibrated. Did you change your avatar? It seems different to me. |
Gauge accuracy is usually 2-3% of full scale. A 100psi gauge would have 2-3 psi of error.
This was fun for me in my previous life. I invented a oilfield completion system that opened based on pressure down hole. Here are the variables... the accuracy of the gauge on the pressure truck they use to open these, the density of the fluid in the wellbore (is it fresh water, brine, KCl water, etc). Regardless, this system has 30% market share in North America and even higher in Russia and other parts of the world... |
| All times are GMT -8. The time now is 09:20 PM. |
