Where would one get a pressure gauge calibrated? When I worked in the lab our load cells and torque wrenched were sent out to calibration every few months and before and after every big test program, but we never used air pressure gauges.
Tire vendors at the track often have one set up for teams to use. In everyday life, I have no idea. . |
To sum it all up-compared the new to the old-I threw 4 away.
It is not scientific-law of averages. I now have three that read the same. |
I have 2 sets of CIS gauges, both purchased at the same time (they sent me 2 by mistake and told me to keep it). at higher pressures they DO NOT measure the same psi.
I have thought about the same with a tire pressure gauge since I just bought a nice one to go racing with. I figure its all relative. that is, if you determine 20psi is what you need for cold pressure, then as long as you ONLY use that gauge, you will never know or care if it is accurate or not. you just need it to be consistent. |
It doesn't matter if they are digital or analog, you will need to calibrate them against a known standard.
How do you calibrate a gauge?
Calibrate me now....or calibrate me later :) |
Most good gauges have screws for changing/adjusting the zero and span. Cheap ones will not.
I'm screwed ;)
Don't remember the tire-gauge brand but the dial says Ashcroft on it.
It is very accurate! My mechanic gave it to me when i started autocross. Told me accurate tire pressures are very important. |
Someone needs to do an R&R sudy....
:D http://forums.pelicanparts.com/uploa...1562605206.jpg There’s a couple of ways of calibrating them . Most common being Dead weight , or a calibrated by pumping against a calibrated “base gauge “ or calibrated transducer and fluke etc Never put my tire gauge on a deadweight , but calibrated against a crystal when new and it was dead on . Edit : it’s a long acre btw http://forums.pelicanparts.com/uploa...1562605206.jpg |
IIRC, NIST uses manometry for this range of pressures.
Here is a scientific instrument house: https://www.coleparmer.com/p/nist-traceable-pressure-gauges/59678 I dunno what the engineers use. But I do know you can git as deep as ya wanna with this... |
And all this science I don't understand .
It's just my job five days a week . |
| All times are GMT -8. The time now is 07:33 AM. |
