-   -   Accuracy if tire Pressure gauges rant (http://forums.pelicanparts.com/off-topic-discussions/1032731-accuracy-if-tire-pressure-gauges-rant.html)
gtc 07-08-2019 11:31 AM
If you sort through them carefully, McMaster has some reasonably priced NIST certified gauges. You could probably build yourself a very accurate tire pressure gauge for ~$100 - or less if you took the hose and valve from an old gauge.
Here's one for example, accurate to +/- 1%.
https://www.mcmaster.com/3543K21
Porchdog 07-08-2019 11:41 AM
We need calibrated pressure gauges at work. We buy new ones every other year - it's less expensive than getting them calibrated by an outside vendor.
At my previous job we had test gauges all over the plant that needed to be calibrated. We had our own, in house metrology lab. They calibrated measuring tools, pressure gauges (deadweight), thermometers and scales.
That was pretty handy for my personal stuff.
My digital and analog gauges haven't been checked in years. They do match each other and they exactly agree with the TPMS on two cars, so I think they are good enough for my purpose.
RWebb 07-08-2019 02:35 PM
ok, page 5 so I'll say it...
Nitrogen
Sooner or later 07-08-2019 02:45 PM
Still loses pressure but at a slower rate.
ian c2 07-08-2019 02:46 PM
High purity nitrogen?
RWebb 07-08-2019 02:51 PM
yes, high purity with all the isotopes lined in little rows
RKDinOKC 07-08-2019 02:58 PM
Yep, the Ashcroft dial looks like that, but only goes to 60psi, has a rubber cover and bleed valve and line with end to hook on tire valves.
KFC911 07-08-2019 03:10 PM
Originally Posted by 1990C4S (Post 10498283)
It is very unlikely that any measuring device you own is calibrated properly.
A cheap tire gauge? Nope.
An expensive tire gauge? Maybe. But not if it's old.
A sweep style meter? No.
Torque wrench? No.
Vernier? Probably okay.
Micrometer? Likely okay.
Ohmmeter? Likely no.
You should not be surprised.
My BS meter? Likely OK...I'm never surprised tho'
1990C4S 07-09-2019 04:56 AM
That one may be calibrated for life. Or it may me be beyond repair.
KFC911 07-09-2019 05:39 AM
^^^^ It's actually quite binary....an idiot light!
O reading = No BS
It moved = BS ;)
Now GOML....
wdfifteen 06-04-2021 10:31 AM
I have a few tire pressure gauges that I’ve accumulated over the decades lying around and I noticed two of the gauges were giving me wildly different readings, and none of them totally agreed. I didn't know which ones were right, so I got a new Joes Racing tire pressure gauge because it’s supposed to be the gold standard of tire gauges.
I rounded up the gauges that I have and compared them to each other and the TPMS on the right rear tire of my Volt to try to find a consensus. For what it’s worth, here are the results:
TPMS – 38 psi
Gauges, Left to right:
AMFLO - 38 psi
Accu-Gage – 40 psi
CH – 35 psi
Accu-Gage – 38 psi
Joe Racing – 40 psi
Milton – 40 psi
Silver stick – 34
Blue stick – 40
http://forums.pelicanparts.com/uploa...1622827821.jpg
thor66 06-04-2021 01:05 PM
Consumer Reports has your answer
smadsen 06-04-2021 09:44 PM
Buy a gauge that can be calibrated. There are companies that calibrate things, i.e. torque wrenches, tire gauges.... Request your gauge be calibrated to the area you usually measure, like 30 lbs on a 0-60 gauge. What's accurate at 20lbs. might be off at 40lbs.
porsche tech 06-05-2021 12:02 PM
Remember these? Used to come in the glove box of every new 911. Then the leather case became a cheesy black plastic one, then no more TP gauge.
http://forums.pelicanparts.com/uploa...1622919575.jpg
rusnak 06-05-2021 02:33 PM
^ on one of these tire pressure gauge threads, I did a comparison between one of the VDO gauges, an Italian made analog tire inflator, the Intercomp digital calibrated gauge, and the Steelman digital tire inflator.
I found that the two tire inflators are very close, and they agree with the Intercomp within less than 1 psi. The VDO gauge was way way way off.
A930Rocket 06-05-2021 04:14 PM
My friend bought a Longacre gauge at the track last weekend. It wouldn’t work on either of our cars. He went back to the track side vender and they tried another gauge on a third vehicle. It didn’t work either. Maybe everyone was using it wrong. 😳
I used my trusty gauge all weekend. Set my tires at 29 cold and when I came in, they all read 31, except the left front was 35. Tire wire at the edge was all uniform.
I’ve read a tire pyrometer is best, but needs to be used at the pit to be accurate.
herr_oberst 09-08-2024 10:23 AM
It looks like the $28 JACO digital (dial type) is worth a look
<iframe width="560" height="315" src="https://www.youtube.com/embed/vHfv9FoPQnY?si=-djvXZxA-5WjWM1W" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
red 928 09-08-2024 12:55 PM
my car has a built in tire pressure gauge.
if the pressure gets too low,
the light on the dash comes on.
All I have to do is pump the tires up for 5 or 10 seconds
and the light goes out.
problem solved. ;)
Sooner or later 09-08-2024 01:14 PM
So does mine.
http://forums.pelicanparts.com/uploa...1725826604.jpg
afterburn 549 09-08-2024 02:56 PM
I never ever thought there would be so much inaccuracy in a simple gauge until it happened to me.
Project Farm was pretty informative! (and proof)
As tires and cars get more and more finicky this becomes more and more of a problem.
Now I don't trust my "Joes",
I never ever thought I would say this ...
But I am going to HF to Buy a Merlin, and or somewhere and get Eatenwolf and Jaco!
Thanx for the links!
