Nice ride
Go with a coyote motor!
dolor et pavor Copyright |
![]() A darned good post with sound advice from one who has been there-done that. Yep GH85, the Ford performance 302's aren't cheap. But all forged internals aren't for a Chevy small block either.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Banned
Are the Ford motors making tons of power or just have to be built extra sturdy so they don't grenade themselves?
Counterclockwise?
Did I see the weight on the 3 motors?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Nope.
The 235 is all cast iron. The 300 is also all cast iron except hypereutectic pistons. The 300 has a roller cam and .5 increased compression over the 235 (9.0 vs 8.5). The 390 is running the same cam as the 300 but upgraded Al heads and another .5 increase in compression over the 300 (9.5 vs 9.0). The 390 is also all cast (also hypereutectic pistons) but is blueprinted (vs the 235 and 300 NOT blueprinted). 235 - all cast 300 - Difference from the 235 - roller cam, hypereutectic pistons, increased compression by .5 390 - Difference from the 235 - roller cam (SAA), hypereutectic pistons, Al heads, blueprinted, increased compression by 1.0 Based on that, I assume the 235 and 300 will be essentially the same weight (all cast iron) and the 390 will be lighter by the difference in weight between cast and Al heads, so what 50-60#s?
Home of the Whopper
That's a nice summary Steve.
I pulled the trigger on the 235hp. With the money I *saved* I am getting a disc brake conversion kit. Thanks again for all the input.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
I had a '65 Chevy Impala 2 dr when I was 16. It had a low powered 350 2bbl and a 4spd with 4.10 gears. It was fun, but not really all that fast, but even then the drum brakes sucked. I'd have really loved to have disks.
The 235 hp motor is that with stock cast iron exhaust manifolds and a single outlet exhaust ? Are you planning on running steel tube headers and a dual exhaust ? I would think you can pick up a little more power with a well designed exhaust . I would think 250 hp in that chassis would be a lot of fun and probably fairly economical on fuel . Also is that 235 with a 2 barrel or 4 barrel carb ? Have fun with it .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Home of the Whopper
Shoot, that reminds me...
I need to get some headers! Not sure about the exhaust setup on the dyno, I would assume headers to get the bigger numbers. It is a 4bbl. I am pretty excited, except that I havent told wifey yet. She will find out Wednesday when the big box arrives!
UnRegistered User
Ask for forgiveness, not permission!!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Street car engine
Just remember the old saying: "Horsepower sells cars, torque wins races!" If I was making the choice, I think I would pick the 300 hp engine and pop on one of the new 4 bbl type fuel injection units. Just my .02 cents worth!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
The 235 will run harder than you might think and you can upgrade the brakes (which you should do anyway even if you went flat out stock).
It is essentially impossible for me to walk away from HP... 1500 or so pounds with fluids and some 300ish HP. Really...really...really LOVE horsepower.... angela ![]()
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Gon fix it with me hammer
Remember HP is what drives the Stang into the crowd
Torque is what makes it plow right through it
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 08-23-2019 at 01:44 PM.. |
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Good choice on the brakes. Probably want to do the shocks and take a good look at the front end while you are in there to do the brakes too. Those parts are really reasonable (compared to the P-cars).
Home of the Whopper
You guys sure are good at spending other people's money!
But good point, while the cars on the lift with engine out, may as well refresh steering and suspension.
