VFR750's Avatar
iRacing a Miata at Lime Rock
Just started iRacing. Thought I’d go simple with a spec Miata at my home track: Lime Rock Park.
After so many real laps in a 911SC the track is pretty realistic even if it is the old layout.
Why don’t Miatas oversteer under lift throttle? Damn 50-50 balance.
Finding out my 911 way of scrubbing speed and rotating the car by lift-throttle and hanging the tail out is completely useless in a Miata. May have to upgrade for the GT3, I need a more comfortable 38/62 balance. 😁
Old 10-07-2019, 06:02 PM
(the shotguns)
berettafan's Avatar
Been a few years but a Miata at lime rock was my absolute favorite thing to do on iRacing. Great track not too hard to memorize. That last turn onto the front straight was a little tense and the right onto the uphill bit was also a great place to screw up.
Old 10-07-2019, 06:28 PM
(the shotguns)
berettafan's Avatar
also while I never did actual track time I did autocross my 70 911 and a 90 Miata for a period of time. Hated that you couldn’t lift to rotate the Miata as well as the 911. Lost interest in auto x the Miata and got priced out of air cooled 911s.
Old 10-07-2019, 06:30 PM
Finding out my 911 way of scrubbing speed and rotating the car by lift-throttle and hanging the tail out is completely useless in a Miata. May have to upgrade for the GT3, I need a more comfortable 38/62 balance. ��
That's a problem with the game physics or the setup of the car, because after having 2 miatas (3 really, '97 with stiffer suspension and 15x7, 2004 turbo with 15x8, and the missus had a '99 with 15x7.5) I can tell you that you absolutely can get throttle lift oversteer in a miata. A miata is more likely to catch itself once it's scrubbed some speed than a 911 which will end up going backwards, but it's still going to tighten or even slide. The first time I tried taking a corner extra hot and using the throttle to tighten the line, it got far more sideways than I expected until it scrubbed enough speed and then it jerked back in line so hard that I hit my head on the top at the top of the driver's side window. That was an educational experience.
Old 10-07-2019, 06:52 PM
DanielDudley's Avatar
Miatas don't rotate, they scrub. It isn't bad, it is just different.
Old 10-08-2019, 01:46 AM
VFR750's Avatar
That is what I noticed. Makes the downhill really fast.
Braking just seems numb and without feedback. I am constantly overcooking Big Bend looking for trailing throttle steering that isn’t there.
Time to play with the FOV and steering sensitivity.
Old 10-08-2019, 04:15 AM
