Home of the Whopper
How to repair stripped stud threads?
Tightening up nut for a master cylinder on a brake booster, and all of a sudden the nut was loose again.
Took it all apart and noticed the studs on the brake booster are chewed up. I was thinking about filing down the remaining threads and tapping the stud to the next size down. Then I read about loctite 660. Looks like this might work if I apply, let dry, then thread? Anybody use this stuff? Or something similar?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
That’s one of those fasteners that I think is fairly critical. I would either replace the stud or replace the booster. You may have to remove the booster to replace the stud, I’ve got no idea what car we’re talking about here.
Not sure what you mean by tapping? You have two choices, first is to use an under sized nut, not the best since you are working with brakes here. Best solution is to pull out both studs and replace them. Use plenty of Kroil to break the metal bond loose.
Home of the Whopper
Its on a '67 Cadillac.
Just bought the booster and MC and somehow stipped the threads already. Its the one circled in red. By tapping, I meant re-threading with a die. Applying the liquid metal, loctite 660, JB weld, or similar, letting dry, then threading to the original thread. Or sanding down whats left of the threads and thread to next size down. The existing threads are metric at 10mm x 1.5. Next size down is 3/8 x 16. Not much smaller, but should be enough to get a good bite. Next option is a new vacuum booster at ~$125. I tried removing the stud but couldn't figure out how to do it and was afraid I was going to ruin the new booster. Are they pressed in or threaded? Double nut with some heat?
Control Group
How is it there are metric threads on a 1967 Caddy?
She was the kindest person I ever met |
Here is an idea for a rig. I bet the threads are only stripped at the bottom of the stud. Use a stack of washers, or larger nut to take up the space, then put the correct nut on the end of the threaded stud , where the threads are still good. If it holds tight, you are good to go !
No left turn un stoned |
Home of the Whopper
Yup, parts made in China.
Took a few minutes to find the right Die, because I was trying all the metric stuff. Tried the washer trick, no bueno. The threads stripped because the proportioning valve plate was off by just a little, and was scraping the threads as I tightened it down. So they are stripped from the beginning to about half way. I will get a pic when I get home tonight.
You do not have permissi
Tapping would require re-threading the inside of the hole (female) and buying a new stud that matched .
A die would cut/clean up the outside of the existing threads (male). Plan A. Trying to save the existing stud would be my first choice. Plan B. Replace stud. Plan C. Buying a new booster. Make sure the tool is lined up at all times because it will want to walk around following the goobered part. Go very slow with pressure and use oil. It depends on how much thread is remaining and if the nut seats past the damage. (The hack in me would zap a quick weld dot on top to keep it from loosening while pressing in turning, but that would be wrong.) No idea here. They could even bolt from inside. If using heat to remove the stud, that plastic vacuum connector should probably be removed first. There is a rubber seal around the fulcrum plate and probably another one for the exit shaft next to the stud. Use high and localized heat right at the base to melt the Locktite. Oxy/Acetylene or MAPP with a small welding tip. Getting an exact new stud might be tedious depending on your schedule. McMaster-Carr will have them. Might be easier to buy a new booster depending on time/money/tools.
Team California
What was wrong w the old booster? Was it bad?
Denis |
Home of the Whopper
Not sure if it was bad, but it was ~50 years old!
Brakes didn't work too well mostly because swollen rubber lines. Decided to go all new.
Might want to put the old one back on if it was still working....
I would never use a POS Chinese brake part on any car I own.
I bet you can get the original one rebuilt and working, or find a new GM part.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Control Group
Speaking of Appalachian Engineering, when I had a similar situation with an exhaust manifold nut on my old Tundra I snugged the nut up good and tight and then welded it on. (Not that I recommend that in your case)
Given that this is your brakes, I would get a genuine US made part if possible and pitch that (possible) POS.
Team California
Doesn't it tell you something when a component still works fine after 52 years? Like maybe it was well made?
Denis |
Team California
Replacing the soft lines, (rubber), was absolutely a smart thing to do. Vital maintenance. But replacing hard parts like a MC and booster w massively inferior replacement parts is not very smart. Those are things that get replaced when they fail or show signs of impending failure. Never prophylacticly replace quality factory parts w Chinese crap.
Denis |
If it holds internal negative pressure, i.e. vacuum, the old rubber seals are there. (for now) The rod spring tension with the shaft lubrication will still be unknown. It should slide and return by pushing on it. |
