Originally Posted by RNajarian View Post
If you are traveling in the HOV lane and your exit is 1 mile away, you may not have a broken yellow/white line to exit before your exit. Happens to me all the time.
Consequently, I cross over the double yellow/white line to exit the freeway. Perhaps this is the circumstance in which it is discouraged but permitted.
Which means that you should figure out the last HOV exit before your freeway exit and exit into the main lanes there.
The HOV lanes that are just painted are great, if there's an accident or break down, you can still get around the issue, but it also means that some folks will use it as if it was just another lane which is not how it's supposed to be used.
Old 01-02-2020, 04:46 PM
AutoBahned
RWebb's Avatar
No, it is not prohibited, toebra. Can you read?
https://www.mercurynews.com/2012/09/28/can-you-cross-a-solid-white-line-on-a-california-road/
Old 01-02-2020, 04:47 PM
Detached Member
Hugh R's Avatar
Think of a solid line as a wall.
Hugh
Old 01-02-2020, 05:15 PM
AutoBahned
RWebb's Avatar
... and you'd be wrong
tho it won't hurt to not cross a solid white
Old 01-02-2020, 05:25 PM
Still here
pmax's Avatar
On further investigation, seems like the DWL rule is from the feds.
Old 01-03-2020, 12:01 PM
Control Group
Tobra's Avatar
The California vehicle code is pretty nebulous about a lot of stuff, legal and illegal, not by mistake.
Old 01-03-2020, 01:07 PM
