Model Citizen
herr_oberst's Avatar
Your bike has a bolt at the seat stay (seen in the picture, it's above the drive side dropout) to split the frame to remove the belt. It's actually easier than removing a linked chain.
This is a driveline belt for a bike. It's not an automotive belt, it is a belt specifically made for a bicycle. There are differences in the quality of the belts you can buy, but there are standards as to the length, and the profile of the teeth.
Count the teeth on the belt to determine the length of bicycle drivetrain belt that you need.
Old 02-13-2020, 03:28 PM
I've had it off a few times..the hardest part is the cable that connects to the 8 speed hub. There is a drop-in for the nut that is on the end of cable that is difficult to get seated and then the cable always needs to be re-adjusted. Do-able, but not fun.
I did re-order the same belt from Vilano. I'll prob just stick with them for replacement.
I first thought I could just pick one up from my local auto parts. I see what you mean.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-13-2020, 03:40 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
I personally would try Bohnings adhesive for fletching( putting feathers onto arrow shafts),rather than gorilla glue, to attempt to reinstate the missing teeth. There is a lot of torque applied to each tooth though when it's engaged with the sprocket.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 02-13-2020, 03:46 PM
Hmm, do they make a flexible JB Weld?
J/K, yeah, absolutely no to gluing the teeth back on. I was kidding.
Old 02-13-2020, 03:50 PM
If a few more teeth break off....the bike will set until the new belt arrives.
I still have my other road bike...if I want to bring that inside for the rollers.
As far as outside riding..there is a good foot of snow now...we had better weather for biking in Jan.
98 Honda Prelude
22 Honda Civic SI
Old 02-13-2020, 03:55 PM
Surprisingly, the new belt arrived today!
The original says 'Gates' on it. This one feels/looks the same but says 'CDRIVE'
I'll prob order another one for a spare. It does look like it's unique to bikes only.
98 Honda Prelude
22 Honda Civic SI
Old 02-15-2020, 11:40 AM
Arrow
Old 02-15-2020, 11:52 AM
^^^ Is that an Alfine 8 speed hub?
edit: I just looked closer and don't see a shifter cable.
They're quiet riding. Do you like it?
98 Honda Prelude
22 Honda Civic SI
Old 02-15-2020, 11:55 AM
908/930's Avatar
You can try an Industrial supplier not automotive, 8M1248 timing belt.
Old 02-15-2020, 01:54 PM
^^^I did..online. The few that showed pics looked wrong. I don't want to order one that won't fit.
I'll stay with Vilano for replacements...if this one works ok.
Three years use...is ok by me.
Thanks!
98 Honda Prelude
22 Honda Civic SI
Old 02-15-2020, 02:51 PM
Eric Coffey's Avatar
Looks like they have switched to Taiwanese-made timing belts:
Taiwan Synchronous Belt company
Might be able to source them direct (sales@twbelt.com) or through a distributor for cheaper.
Should be 156 tooth, going by their chart. Just need to know the belt-width, as you already have the pitch and length (8M-1248).
Old 02-15-2020, 03:06 PM
