I’d fill the holes from the outside with jb weld and the silicone a patch of thin metal or plastic on the inside over the area. Should keep the rain out no problem.
This is sad to read... but since it's Friday, I will share a derogatory word for his type of shoddy work: "plumbtrician"... Sand a bit around the holes on the outside so the JB weld "holds". Don't fix anything if you plan to put the screws to the contractor.... as it were.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
