AutoBahned
Panasonic interview on PV Power & Storage
In Oklahoms it is a waste of money. |
AutoBahned
we aren't quite there yet either in the foggy sunless PNW*
one neighbor put up PV on his house when he built it, but that makes more sense * BTW, stay away!! |
There are only two value streams for storage. Either rate arbitrage or back up. Rate arbitrage under current TOU rates would take about 100 years to pay back. I have PG&E and had three outages last year. I lost MAYBE $50 in food since I did not have a generator at the time. A $250 generator and that wont happen again. In the 15 years before 2019, my house had 2 outages of more than 4 hours, and neither was more than 8 hours which means back up would take about 1000 years to pay back. I would focus much more on V2H where you can use your EV battery as a battery backup at home. |
Oh of course, solar is a complete no brainier here. I meant the value add for a battery on top isn't there.
Living in an HOA, I would be curious to see the financials of a community microgrid. O&M would be the question mark but a community where all houses have solar/storage with a community microgrid for balancing could be an intriguing alternative to typical utility grid connection. |
Reparations for neanderthals! '70 914-6, 1965 Mustang GT - RIP, '74 911, '01 Box S '12 Ducati 848 Evo - RIP, '16 Yamaha R1, '13 Aprilia RSV-R |
I’m looking forward to when an electric vehicle plugged into my house can work as a battery storage system at night. I’ve already got the solar panels on my roof making plenty of excess power.
Hopefully TESLA will offer this setup rather than the powerwall battery. |
canna change law physics
SDGE is no longer paying anything for residential solar sent to the grid. If you want to zero out your electric bill, you need energy storage. There is a way to get Net Metering, but you pay through the nose for it for your regular electricty. This is for new installs. A 10kW system with high cycle lithium batteries (7000-10000 cycles) in Houston will cost about $60K installed, which includes a NG/Propane Generator. I expect this will be $75K in SoCal. If you drop the generator, you could save about $10K. 10kW will produce around 65 kWh per day, or about 24,000 per year. The first 750 kW on SDGE is $.19 (9000 kWh/yr) Everything else is $0.39 (15000 kWh/yr) Value is around $7.5K/yr - So payback for the ENTIRE system is around 10 years without incentives, or 9 without the backup generator. If you installed this year, the Federal Incentive is 28%, which drops the payback period to about 7 or 6 years. There also might be local incentives.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I'm not sure what your "first 750" means? If you install solar you are required to be on TOU rates. There is a small reduction for baseline usage but the rates are still based on the time of day. I'm also not sure how you assign the "value" of $7500/year. The only way that's possible is if someone was already paying $7500 or more a year for electric and I'm sure there might be some mansions averaging $625/month in electric but not anyone I know. In some areas of the US back up power might be valued, but like I said, 2 outages in 15 years over 4 hours means backup power is worthless, especially calculating payback, around here. |
They can make sure there is a minimum amount reserved but it's hard to say how much they should reserve. 10 miles? 20? Your scenario where the excess solar would charge it is an ideal scenario. Unfortunately currently, solar systems are sized for your average yearly use, so at the end of the year you come out to about 0 for the year. The V2H scenario, you'd have to size it for peak summer usage to cover an outage then, and the excess the rest of the year would usually be wasted. However that is where block chain community energy could step in and things get very interesting! |
The first 750 kWh are at a lower rate. Anything beyond is a higher rate.
AutoBahned
the value add for a battery on top (inside of ~~ 7 years) is the ability to have power during and after the next fire (or quake maybe)
