-   -   SOS Need help identifying THIS hose...... ASAP (http://forums.pelicanparts.com/off-topic-discussions/1055224-sos-need-help-identifying-hose-asap.html)
PRE-H20 03-17-2020 11:45 AM
Hi Guys..... I need some help with a broken hose and getting a new one. I don't know what it is called so I cant order a new one.
I have a 2005 Super Charged C230 Kompressor 1.8
It is located on the passenger side, here are a couple of pictures to orient you guys........
PLEASE send me the part number if possible.
http://forums.pelicanparts.com/uploa...1584470674.jpg
Scott Douglas 03-17-2020 11:52 AM
If I had to guess, I'd say nothing is actually 'broken'. It looks like the hose came out of the coupler.
asphaltgambler 03-17-2020 11:54 AM
It looks like the charge air hose from the compressor, the one that's pulled away with O-ring.
E38Driver 03-17-2020 12:01 PM
Maybe try this site.
https://nemigaparts.com/cat_spares/epc/mercedes/1/
Dave
PRE-H20 03-17-2020 03:13 PM
Scott..... you were dead on!
Once I got a chance to really get in there and see what was happening, BINGO.
The hose had come loose (had some work done on it recently and it may have been reassembled incorrectly.
Seated the hose and buttoned it down..... now NO surging whatsoever!
Thanks fellas!!!
pmax 03-17-2020 03:21 PM
Is this still a "car guy" forum ?
Scott Douglas 03-17-2020 03:30 PM
The easy fixes are always the best!
Glad to have helped.
PRE-H20 03-17-2020 03:33 PM
Still amazing to me how brave a keyboard makes some of us.
Either way, thanks to you guys, it was a simple fix once I was able to get in there and see what was happening.
Scott Douglas 03-17-2020 03:35 PM
Your first picture was the key.
Good job using the camera, or was it a phone?
PRE-H20 03-17-2020 03:38 PM
Thanks Scott.... was my phone.
pmax 03-17-2020 03:41 PM
Hah, I was actually going to add WFH or the equivalent in my previous post.
Good thing I toned it down !
LWJ 03-17-2020 03:45 PM
That is what I love about wrenching: Nothing more than problem solving.
stevej37 03-17-2020 04:09 PM
If you did have to replace it...I'll bet it's not a $10 hose!
pmax 03-17-2020 04:17 PM
Pretty sure Home Depot has a $10 replacement which works exactly the same.
That spring (?) braced air hose feeding a standard accordian looks way overdesigned.
Originally Posted by PRE-H20 (Post 10787783)
Arizona_928 03-17-2020 04:25 PM
German intercooler hose. Of course it's over engineered
john70t 03-17-2020 05:29 PM
It's designed to keep a rounded internal profile and follow the engine while it torques in the mounts (might want to check those).
There is no such thing as German over-engineering.
Such talk could get you in trouble.
And their sense of humor needs no correction, thank you!
911boost 03-17-2020 05:48 PM
My Powerstroke diesel has a hose coming off the intercooler very similar to that. It is a know weak point that sometimes comes apart under hard acceleration when towing. Fortunately I was right near my house when it happened. Went aftermarket to solve that issue....
pmax 03-18-2020 09:54 PM
Interesting.
To hold the profile, assuming the internal pressure is lower than atm, I was wondering .... wouldn't it be better to have the springs inside the flexible hose ?
nota 03-19-2020 06:05 AM
Originally Posted by pmax (Post 10789936)
Interesting.
air is under pressure from the SC [kompress] so no
pmax 03-19-2020 10:46 PM
^^^ Yup, that would explain it.
