Mike80911's Avatar
Help with air compressor issue
I have a 5HP 60 Gallon craftsman air compressor. The issue is that when I use it the tools lose power very quickly. If I try to use a cut off wheel it will work fine for a minute and then slow way down where it is totally ineffective. If I wait a minute and then start again it will be fine and then back to very low power.
Anyone have any ideas with what might be the issue
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 10:05 AM
Brew Master
cabmandone's Avatar
Is the compressor running and you're losing air pressure or not building/maintaining pressure while using the tool?
Nick
Old 03-30-2020, 10:08 AM
Mike80911's Avatar
Originally Posted by cabmando View Post
Is the compressor running and you're losing air pressure?
The compressor will run when the pressure drops as it is supposed to. But not necessarily when I am using the tools unless it drops below the set point
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 10:10 AM
Brew Master
cabmandone's Avatar
Wait! Have you drained the water out of your tank lately? After reading your OP it looks like you're saying the pressure drops off and if you stop for a bit the cutoff wheel will work fine again. I think that can be caused by excessive moisture in the airlines.
Had to delete that previous reply.
Nick
Old 03-30-2020, 10:16 AM
Cut off wheels can suck up a lot of air. Many if not most home compressors can't keep up with that demand.
Old 03-30-2020, 10:22 AM
Mike80911's Avatar
I will check for that thanks
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 10:43 AM
Mike80911's Avatar
Not just the cut off wheel though even if I use the impact gun , after removing 2 lugs I will have to wait a minute for enough power to get off another 2. It is a fairly large compressor 5HP 60 Gallon 240 volt so not your average small home unit
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 10:45 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Something is not right. What is the pressure in the tank when filled?
Outlet regulator is max open?
1981 911SC Targa
Old 03-30-2020, 10:49 AM
What size of air hose and how long? Any "issues" between the tank and tool?
Good luck!
gtc gtc is offline
abides.
gtc's Avatar
Sounds like either your hose is too small or you have a problem with your pressure regulator.
Graham
1984 Carrera Targa
Old 03-30-2020, 10:50 AM
What is the shut-off pressure and what is the re-start pressure?
Old 03-30-2020, 10:53 AM
908/930's Avatar
Do you have a filter regulator near the compressor? It is possibly clogged or too small of a filter regulator, have you oiled the tools lately?
Old 03-30-2020, 10:55 AM
Mike80911's Avatar
Thanks for the replies
using a 3/8 hose 50 feet long
120 PSI is shut of pressure not sure of start pressure
Model is Craftsman 919-165600
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 11:27 AM
Get a 1/2"....25' if it will reach.
Yer welcome
Old 03-30-2020, 11:30 AM
Still Doin Time
asphaltgambler's Avatar
You may want to check the compressor tank outlet fitting to see if rust / scale has built up restricting air flow through. It happens.
Old 03-30-2020, 11:44 AM
Mike80911's Avatar
Thanks guys. I will check everything mentioned
89 930 Cab Black
11 Cayenne
Old 03-30-2020, 11:55 AM
A 3/8" hose would not suffice for my Powernailer to drive nails through 3/4" Hickory flooring...
You've been hosed
Old 03-30-2020, 11:59 AM
What pressure are you running the cutoff tool at?
Per the manual that compressor puts out
Approximate Cut-in Pressure 100
Approximate Cut-out Pressure 130
SCFM @ 40 psig 14.2
SCFM @ 90 psig 9.9
Most cut off tools need 11 - 14cfm.
Oilless compressors don't put out much air.
Old 03-30-2020, 12:23 PM
An impact wrench just needs 90 psi, not constant at the tool. Two lugnuts and done.....NOPE
Old 03-30-2020, 12:37 PM
Charge up the tank. Stand beside the tank gauge and run the tool until it stalls/stops, then observe the pressure drop on the tank.
When you say you wait a minute then the tool works again, is the compressor motor running in the interim? If not then you likely have a supply /pressure drop (in the hose) issue.
It would be helpful to temporarily put an air pressure gauge at the tool.
Old 03-30-2020, 01:14 PM
