My Wolf Range Hood is Way Too Loud
Way way too loud, even on low speed.
Has anyone added a VFD, or swapped out motors? It works great, I could live with a lower speed that moved less air and made a lot less noise...
Any of you rich guys have the same problem?
Old 04-07-2020, 01:55 PM
Far from rich but had an AirBnB last December with one and it was way too loud. If I were to spend that kind of money on a kitchen I would look for a way to use a remote fan.
I just built a commercial kitchen with a 3000 cfm hood and it was no where near as loud as the Wolf.
Old 04-07-2020, 02:34 PM
weekend wOrrier
Just out of curiosity, a lot of these internet range sites mention/ rate CFM exhaust, as well as overall noise levels for each model of fan.
Are there any sites which rate your particular model in terms of noise- i.e.- is this a noisy exhaust fan by nature, vs. a quieter exhaust unit with a potential setup issue?
Some of the exhaust fans I looked at were dogs right out of the box in terms of noise levels. Some of these sites had user/buyer feedback regarding this issue. There seemed to be huge variability between not only brands, but between models within a brand.
Old 04-07-2020, 03:16 PM
I can check the specs, but the noise appears to be entirely air moving over the grills and through the fan.
No motor noise, no rattles, no vibration,
Old 04-07-2020, 03:40 PM
Platinum Member
dad911's Avatar
Was this a remodel? using old ductwork? Typical ducts are 6", commercial (wolf) may require 8 or 10"
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 04-07-2020, 04:00 PM
Platinum Member
dad911's Avatar
There are variable speed remote controllers for hoods. It's a simple motor, I suspect a ceiling fan controller would work also.
Old 04-07-2020, 04:04 PM
I built my own hood with an 8" duct straight up through the roof. I installed a powerful in line 8" fan, but way up in the attic. I used an infinite control switch. So much quieter with the fan distanced from the hood. I mounted the cleanable filters in the hood right above the stove.
Old 04-07-2020, 04:16 PM
Zeke's Avatar
I don't have a Wolf hood (but I do have a 1976 Wolf 3 foot range); the hood is by Vent-a-Hood. I did not buy the internal mount blowers but instead mounted a single fan in the cabinet above near the ceiling. It's still noisy at full throttle but not so much that you can't comfortably talk while at the range.
Old 04-07-2020, 04:50 PM
Get a muffler (Fantech makes a great one. They call it a silencer), goes above the unit up in the attic. It reduces 50-60% of noise. What you are hearing is the velocity of the air moving through the unit and I bet the ducts aren't insulated. Wrap insulation around the rigid pipes may help. For further noise reduction, mount an exterior motor that pulls air through the unit and remove the motor under the hood. I first learned about their mufflers at a builder show about 15 years ago. Now I install one on almost all the kitchens we built. I know which hoods make the most noise and few are very quiet like a Vent-A-Hood.
Old 04-07-2020, 05:29 PM
Grey poupon
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
Old 04-07-2020, 05:40 PM
944 S2
944 S2's Avatar
A howling Wolf.....image that!
Does anyone make a Vent-a-Hood type remote roof blower -- but one the fits on a vertical exterior wall as opposed to the roof models ?
Current kitchen vent exits onto a two-story exterior wall.
Always take the high road, it's far less crowded - Charlie Munger
Old 04-08-2020, 03:46 AM
LOL...but he's got the "ventilator blues" instead
Old 04-08-2020, 04:35 AM
greglepore's Avatar
This. I learned about these when I installed my own hood in 2010 using a remote mounted fantec and an empty viking shell. The mufflers are amazing.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 04-08-2020, 04:57 AM
Wolf hood here. Not too noisy though as we have the remote motor mounted on the roof about 9 ft of ductwork away. Very powerful pull and only a sight noise of air moving, but definitely pulls the grease and fumes up into the traps. Get the motor away form the hood.
Old 04-08-2020, 05:40 AM
This is the answer^^. We have a Wolf range (same model as Zeke probably) with a Viking hood that is much like the Wolf hood. Yes, the fans (there are two which can be turned on separately) are very noisy. The real solution is to have the fan moved to the exhaust end of the ducting, again, the further away the better.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-08-2020, 07:54 AM
Banned
Wolf hood there. The fan is an external unit. If you have it on high, its pretty loud, but its also a massive fan pulling air. If you open a window on our 3rd floor, it will clear the whole house is short order!
Old 04-08-2020, 08:37 AM
peppy's Avatar
The modernaire hood that we installed is also loud. It's not the fans, just the volume of air moving through the baffles.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 04-08-2020, 09:53 AM
Zeke's Avatar
The blower fits the duct. You can turn the duct any way you need. Just elbow it out. Try to do it gently with 45º's.
Old 04-08-2020, 10:21 AM
I have a Zephyr insert that was done during the remodel. The ducting is insulated and 8 inch and goes out into the garage where we had to box it in, etc per code. It also came with a make-up air kit that opens fresh air ducting in the basement. On the highest speed its a bit noisy but not terrible.
It has a remote though for some odd reason.
Old 04-08-2020, 10:33 AM
