Hearing protection for gun range shooting
Can you guys send recommendations my way? I already suffer from some hearing loss from my military days so don’t want to worsen it. I’m also shopping for safety glasses. Thanks!
I love mine...but can't remember what they're called right now!
Slim, noise cancelling, and you can plug your phone or whatever into them, too. Found them on Amazon, I'll see if I can find a link.
Guy '87 944 (first porsche/project car) |
Couldn't find my Amazon order...but these at Cal Ranch are basically the same thing.
https://www.calranch.com/razor-electronic-ear-muffs.html
I have used the 3M Peltor electronic ear plugs for several years now. They last 6 to 8 hours on a single charge from the 3 AA batteries in the case. and the sound is cut off around 85 DB or so. The amplify regular sound such that I can hear the full width of our shooting range to what people are saying. The ear muff type hurt my head due to the lupus sensitivity of my skin so these are great
I see you
I use two layers. Foam plugs under a pair of standard Caldwell ear muffs.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I have these and these. I wear the first ones (in-ear) primarily, then add the second ones (over-ear) if there is someone shooting a fire-breathing cannon next to me, and/or indoors. YMMV, and you can certainly do better if you want to spend more money. |
I think that's what I've used as well. The over the ear muffs work really well. i actually found that I started using them in the garage when working with drills, saws, etc...
And if you stick with "dumb" ones, they're cheap enough to have more than a few hanging around the garage and the basement. Hearing doesn't grow back when you hurt it and I'm paranoid.
'78SC, lots of other boring cars... |
canna change law physics
If you need reading glasses, get the safety/shooting glasses with readers built in.
https://smile.amazon.com/Bifocal-Safety-Glasses-SB-9000-Yellow/dp/B00BHL8P7Q/ref=sr_1_7?crid=1UKXZIJCA45PR&dchild=1&keywords=shooting+glasses+with+readers&qid=1586977385&sprefix=shooting+glasses+with%2Caps%2C165&sr=8-7
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I use those plastic and rubber ear plugs under grade 5 earmuffs.
Make sure the earmuffs really grab your head. They need to be tight and a good fit. The best ones I've got are by Husqvarna the chainsaw people. |
Cars & Coffee Killer
This is what I use:
https://www.amazon.com/Radians-Custom-Molded-Earplugs-Tan/dp/B0006GWRJK/ref=sr_1_8?crid=OHR4H01P0VZH&dchild=1&keywords=custom+ear+plugs&qid=1586986734&sprefix=custom+ear%2Caps%2C204&sr=8-8 Except for very large bore stuff, where I put a set of over-the-ear over my in-the-ear plugs.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Just plain old cheap ass ear muffs, no noise cancelling, no batteries, no nuthin'. Either that or plain old cheap ass foam ear plugs.
In spite of how it may sound, wearing both really doesn't help. We proved this to my satisfaction in noise study after noise study at my former employer. You guys want loud? Try standing a 747 wing panel vertically (fore to aft) in a wing jig with three decks of scaffolding next to it. Put about ten guys on each of those three decks, all armed with rivet guns, and have them simultaneously driving 1/4" to 1/2" rivets. The noise literally makes your bones vibrate. The company and OSHA/WISHA recommendations for employees in that environment was a single layer of hearing protection - muffs or plugs, take your pick, but not both. And they test these guys every year for hearing loss.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I see you
IOW, more attenuation is better for your hearing but that also equates to more isolation, which can dull one's situational awareness and can be an additional liability/safety issue in a work environment. However, if noise levels are extreme then dual-layer is recommended, as (unassisted) verbal comms are typically impossible to understand at those levels anyway. |
I use a boring set of Peltors. The bar goes across the back of my neck. therefore I can wear them with a hard hat. This help because I wear the sane ( I have several) pair at work, doing yard work and whatever.
I also carry foam plugs. But I like the muffs at a public range. It’s nice to offer a visual cue to other shooters you have “ears-on”. Might save them from surprising me with a shot.
poof! gone |
Driver, not Mechanic
Peltor and those foam inserts for indoor. Outdoor, just the Peltor. As for glasses, I have some Wiley-X that I can switch lenses from clear to polarized, and some Oakleys for outdoor, but honestly that's just me spending more than I should...
Now in 993 land ...
I use the ones Hickok45 has. I like them waterfowl hunting. I can move them a little to hear conversation better and have them fully protect me in a split second before picking up my shotgun.
https://www.grainger.com/product/9UA93?gclid=EAIaIQobChMImsXBtNPr6AIVEqrsCh3jtwUXEA QYASABEgLxlfD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=EAIaIQobChMImsXBtNPr6AIVEqrsCh3jtwUXEAQYASAB EgLxlfD_BwE:G:s&s_kwcid=AL!2966!3!281698276014!!!g!471328313928! Also disagreeing with Jeff - the plugs and muffs are my go-to when sighting in hunting rifles at the range. Maybe it is different for a permanent noise like an engine. The eve of the roof comes down very far for safety (so people don't launch shots in the air) and this also reflects the sound badly back at the shooter. I cannot stand it with just ear plugs or just muffs but both on, it becomes safe to my ears. What do you hunters use so you can hear yet get a shot off in short order when still hunting? I see products that supposedly let you hear through them, but the cheap ones I tried about ten years back were not working well - they over-amplified noises at any setting and just a slight wind would make you go crazy. G |
Bought three pair of over the ear at Walmart. Cheap and they work.
Slackerous Maximus
Put quality ear plugs in, then your muffs over that
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Thanks guys. I’m buying foams and muffs.
