fastfredracing's Avatar
how far can I cantilever a 4 inch concrete slab ?
I bought a small mixer, and have learned just about enough to be dangerous . I am making a small patio off the back of my house . Almost done, but I need to overhang a retaining wall by about 11 inches to meet where my other deck will be .
This will be a 4x8 slab, and the long side is where I will need the overhang.
There is a similar slab on the other side , that is 6 inches thick, and overhangs by 6 inches .
Any ideas ?
No left turn un stoned
Old 05-08-2020, 10:08 AM
Any rebar in it?
Dennis
Of course! I was thinking about doubling up on rebar. I also have a bunch of sheets of heavy wire mesh, that I have been laying into the slabs .
Old 05-08-2020, 10:17 AM
Information Junky
island911's Avatar
Originally Posted by Iciclehead View Post
Any rebar in it?
Dennis
And where (top or bottom) does it exist?
Old 05-08-2020, 10:21 AM
only pre-stressed concrete slabs can be cantilevered, Fred.
Poured concrete shears at a 45 degree angle.
Old 05-08-2020, 11:05 AM
canna change law physics
red-beard's Avatar
^^^This
James
Red-beard for President, 2020
Old 05-08-2020, 11:16 AM
I see you
flatbutt's Avatar
Somewhere at sometime I recall reading about a length over depth ratio for concrete overhang....I think I'm remembering this correctly but don't bank on it.
Old 05-08-2020, 11:21 AM
Maybe instead of doubling up rebar, space the lattice half the distance and dowl pin it into the deck and go with 6" slab.
Old 05-08-2020, 11:54 AM
MBAtarga's Avatar
I don't understand the vision:
Mark
'83 SC Targa - since 5/5/2001
Old 05-08-2020, 12:43 PM
Ill snap up a picture tonight.
Old 05-08-2020, 12:47 PM
Frank Lloyd Write knows....
Old 05-08-2020, 12:49 PM
908/930's Avatar
Not sure if this would work but, if you drop in 3' x 3/4 dia threaded rod with bent J end into the slab about every 12" starting 4" from the end, and cap the outside cantilevered end with 1/2" steel plate and tension it after the concrete has fully cured (30days). Possibly would keep it under compression so it will not break off. Pretty sure you want to be near centre of thickness of the slab and at least 2" from the surface, so real tight with 4" slab.
Old 05-08-2020, 02:04 PM
vash's Avatar
Can you tie it to the other deck?
I’m not quite picturing it. How high is this overhang? (Off the ground).
poof! gone
Old 05-08-2020, 02:21 PM
Navin Johnson
TimT's Avatar
Now that's just not true ...
Many bridges you drive over every day have cantilevered components.. I.e. outside stringer to fascia is a cantilevered component.. The wheel path is designed to be closer to the support...
However.. considering a 4 in slab there is not enough depth to install the reinforcement needed..
And an 11 in overhang is nothing.. hardy a cantilevered deck..
If you're worried increase the depth f the slab to perhaps 6-8 in prior to the overhang to allow for proper placement of reinforcement
'69 911 GT-5
'75 914 GT-3
and others
Old 05-08-2020, 02:35 PM
wdfifteen's Avatar
You can’t. Even a slab well reinforced by rebar is going to flex. A cantilever will flex in tension (the top will try to get longer). Concrete is great in compression but sucks in tension. It will crack and crumble and fall apart and you will be sad. You’ll need a thicker slab. In other words, “Yer gonna need a lot more than four inches, bub.” You’ve probably heard that before.
Old 05-08-2020, 04:22 PM
A930Rocket's Avatar
To my feeble brain, I just don’t think a mixer making small batches of concrete would help either.
Old 05-08-2020, 04:27 PM
vash's Avatar
There is also failure in creep.
I think it can work if the failures are simply some cracking. But Tim is right. I’ve seen overhangs. We usually post tension in the transverse direction. Plus we have lots of rebar. Lots. Lots.
I’d love to see a pic of what Fred’s got cooking over there.
I always joke with my concrete venders. If I do a pour at my house, I’m pulling a mix design from my files. I’m pouring a high strength mix. Driveway cracks? Sure. My tree roots are gonna struggle.
poof! gone
Old 05-08-2020, 04:31 PM
And of course, at Fallingwater his cantilevers sagged after time. And his patron (the furniture guy - can't remember his name) actually had him double the amount he'd been planning to use.
1972 911T/S MFI Survivor
Old 05-08-2020, 07:19 PM
from Bill Doorley on Vimeo.
Old 05-08-2020, 07:24 PM
Information Overloader
Almost every one of his homes is unlivable, outrageously expensive to maintain and ridiculously expensive to build.
But they certainly are beautiful.
Old 05-08-2020, 07:31 PM
