That's weird. What's the explanation for that?
Team California
I don’t know. Never seen it before.
Anyone else seen this before?
Denis |
Focus, man, focus.
Team California
Denis |
Team California
?? I can read the date code just fine, not sure if it’s coming through in photo but it looks like someone chunked-out the code and re-stamped it. Not a good sign.
Denis |
I see some flash around the number area, which isn't unusual and I think I can read the number 3411 but the photo is too blurry to see much of anything.
Tires are toast, so it doesn't matter. |
Team California
Denis |
Team California
Yep, 3411 and agreed, they’re toast.
Denis |
MAGA
The date code looks official to me.... They obviously have to change the date code in the mold for when the tires are made. Just looks like the date insert was not fully flush in the mold.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
I gave you my suggestion on the tires a while ago. First the front tires, then the inner tries on the rear axel, then the outer rear tires last. The inner rear tires are pretty hard to check out while on the vehicle.
So how is the engine working in the coach and transmission and the other running gear, are they doing well? You could drain each to see how the oils are doing. I had to take the drive shafts out to get them all gone thru. That was a major improvement in the comfort underway. The center strut Bering was done for. And the u joints were Pretty bad to. Getting that system sorted out was so good in the feel on the road. I think the rear hubs are not easy to find. So check your bearings on the wheels in the rear axel. They did rear drum brakes till the mid 80s I think. Are the ones on your coach still original? You sure do seem to be going thru it pretty well, well done! Cheers Richard |
Team California
I have no idea how to check wheel bearings on this thing. I'm feeling pretty good about the roadworthyness of it, once I replace some tires. My RV has disc brakes front and rear, definitely original.
Denis |
Team California
Since I've got some smart guys on this thread, I have a question about chassis grease. I picked up a grease gun today but the selection of grease at Autozone was frankly confusing...they really had a lot of options. This is normally a good thing but I had no idea which one is best?
Here are some pics I took, I can go back and get the one I need:
Denis Last edited by speeder; 09-23-2020 at 09:20 PM.. |
Team California
Denis |
AutoBahned
Valvoline - IIRC, it is SynPower is good - Sherwood uses it I think
get something you can use (nearly*) everywhere - wheel bearings, driveshafts & chassis * I use Wurth HHS clear spray grease for seat tracks, doors, etc. |
Team California
New tires ordered and will be mounted on front when they come in next week. Small town Goodyear truck tire dealer beat every online price on some Bridgestones, some by hundreds of dollars.
![]() I’m on rust patrol now, lots of surface rust on sheet metal parts under the rig. I go after it with my spinning wire wheel after a good cleaning w soap and water, then treat w red oxide primer. I should have taken a *before* pic of the battery compartment but it was nasty, it sits under the floor right where you step into the coach and is exposed to the outdoors. The entire thing was so filthy and rusty that the red cables were basically black, Rainman can’t abide that.
Denis |
Team California
Sorry, photos coming.
Denis |
Red oxide primer isn’t going to be enough to prevent further rust, primer is almost useless in that regard. You need to lay down some decent paint on top of it.
Team California
I generally put a top coat on but the primer alone definitely arrests further corrosion the times I’ve used it alone.
Denis |
For bare metal I prefer a self etching primer, besides, what’s one more rattle can cost?
FWIW |
This is a great thread. Thanks, Denis!
1996 FJ80. |
