-   -   "Offset" Wrenches ?? (http://forums.pelicanparts.com/off-topic-discussions/1063217-offset-wrenches.html)
RWebb 06-04-2020 03:04 PM
I am trying to figure out what problem these Hazet wrenches solve, that regular closed ends don't...
http://forums.pelicanparts.com/uploa...1591308197.jpg
masraum 06-04-2020 03:14 PM
Dunno, but they look cool. :D
Jeff Higgins 06-04-2020 03:19 PM
Top left bell housing to engine nut on a 1963 Dodge Dart with a slant six and power brakes.
KFC911 06-04-2020 03:58 PM
Hangover wrenches :D
wdfifteen 06-04-2020 04:33 PM
Been there. It's not a 25mm bolt head.
Bill Douglas 06-04-2020 04:36 PM
Yep, like most things, it's all about looks.
MBAtarga 06-04-2020 04:57 PM
Maybe used on bolts in the first situation below - where the hole is too near the edge? :D
http://forums.pelicanparts.com/uploa...1591314980.jpg
mattdavis11 06-04-2020 05:03 PM
Anything that has a distributor in the back. 350, 318 are two that had really long runs where those wrenches would be useful.
wdfifteen 06-04-2020 05:11 PM
Starter wrenches and distributor wrenches have a more serious offset. I can see where these wrenches would be an interesting alternative to straight box end wrenches, or a good helper in those places where a six point box end is so tight you can't move enough to get another bite. Just whip this baby on it an get that 1/16th of a turn you need.
porsche356a 06-04-2020 09:41 PM
Rear nut on 356 single barrel carbs...
asphaltgambler 06-05-2020 08:08 AM
You'd be surprised - possibly the difference in R&R'ing the nut or bolt quickly -or- spending half the day finding a work-around. There are many various types / styles of offset wrenches, some ratcheting. some where the offset is greater or more angled then 'average'.
I have a crazy looking offset, angled, dropped, box-end wrench designed for John Deere in-line diesels to remove the starter inside bolt. I bought it when I was in High school working part-time for the local JD dealer. I've had it ever since. I cannot tell you how many other times that I've needed that wrench to successfully remove fasteners.
vash 06-05-2020 08:46 AM
maybe if there is a fastener near a obstacle..it allows more clearance for your handhold?
Jeff Higgins 06-05-2020 09:01 AM
The good thing, though, is that once they get that big, standard and metric pretty much interchange. I think by about the time you're at a 17-19mm or an 11/16"-3/4".
911 Rod 06-05-2020 09:06 AM
You don't need an offset wrench until you need one.
GH85Carrera 06-05-2020 10:16 AM
http://forums.pelicanparts.com/uploa...1591377176.jpg
I always thought of offset wrenches as like this type.
I have just one of those, and I use it for the brake pressure switches that make the tail lights come on for my 911. That style of wrench makes it a lot easier to replace them.
As far as the wrench in the OP, I would say it gives a little bit more torque for the user if the nut is slightly off center. Not much, but a little more lever action.
KFC911 06-05-2020 11:21 AM
....but don't have one :D.
3rd_gear_Ted 06-05-2020 11:29 AM
I call those "gearbox" wrenches.
Corresponding set is open ended and short
Jon B 06-05-2020 11:50 AM
http://forums.pelicanparts.com/uploa...1591382870.jpg
madcorgi 06-05-2020 11:57 AM
Only with the automatic.
porsche356a 06-05-2020 12:49 PM
Originally Posted by Jon B (Post 10893182)
Yep. I made one of those for my 56.
