Socket case on last legs -what to do for replacement?
My google-fu is weak, hopefully theres a cheap solution ive overlooked.
Got a cheap all in one socket set 25 years ago and the case is coming apart.
I want something like it, organized and portable. Wouldnt mind a bit more room.
I dont want a coffee can of sockets and bits. Thing is great except that its coming apart.
Ideas?
Box hardware stores have stuff but theyre full of tools already,
Old 06-09-2020, 01:26 PM
AutoBahned
RWebb's Avatar
can you replace just the clear plastic 'window'?
do you like the way the case is laid out?
do you really use it or just open the toolbox drawer, then open the case and grab what you need
finally... I have seen people trying to create blow molded plastic cases for their socket sets - I swear that is true!
Old 06-09-2020, 01:34 PM
I had one from Black and Decker and the hinge part broke off. It was just a thin strip of plastic anyway - you know the kind.
Called up Black and Decker and they mailed me a replacement.
Old 06-09-2020, 01:36 PM
I've got something very similar without the plastic window in it.
If I were fixing this at home, I'd use one of my wife's old cutting mats that she uses when cutting material. It's thin enough that you could cut a piece that would fit inside the lid and cover the whole lid. Put some silicon caulk on it to hold it in place, I think it would stick.
Does your wife sew?
Scott
'78 SC mit Sportomatic - Sold
Old 06-09-2020, 01:57 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
If the case and hinge mechanism is ok and only the clear
Sheet that is failing, find a good hobby or art supply store and buy a sheet of clear styrene. Remove old and epoxy new. If the hinge and/or latch mech is toast,,,,,
Time for a new set of tools. Donate those and buy a premium set that should come with a case.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 06-09-2020, 02:03 PM
Preferred pronoun:Maestro
Norm K's Avatar
Have one printed?
_
When in doubt, use overwhelming force.
Old 06-09-2020, 02:05 PM
rfuerst911sc's Avatar
How about a conventional tool box ? You said you wouldn't mind more space . There are plenty of socket organizers that could be used in a good ole hand carry tool box .
Old 06-09-2020, 02:08 PM
DanielDudley's Avatar
Doesn't have to be clear. Could be Aluminum or whatever you can score.
Old 06-09-2020, 02:18 PM
vash's Avatar
can the existing box be repaired or reinforced?
poof! gone
Old 06-09-2020, 02:44 PM
You can buy bit holders and socket holders and move all the tools into a tool box.
https://www.zoro.com/eazypower-block-o-bit-case-empty-88289/i/G0565159/?gclid=CjwKCAjw5vz2BRAtEiwAbcVIL6ygQcVY7Xb-tHypXt_aEuDztQywW6l0a5pPzUUllYR1XKArwbWUdBoCUOcQAv D_BwE
Old 06-09-2020, 03:07 PM
pwd72s's Avatar
This might work
https://www.amazon.com/Silverhill-Tools-ATKSBPS-Socket-Storage/dp/B07D5FGHS7/ref=asc_df_B07D5FGHS7/?tag=bingshoppinga-20&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4584345018263797&psc=1
Old 06-09-2020, 03:50 PM
Go old school. Buy some wood and use a router to make one complete with slots for everything. THen engrave the slots with the sizes/names and inlay with something so it stands out.
Old 06-09-2020, 04:16 PM
Platinum Member
dad911's Avatar
This is the by far best organizer I have used over the years. Wish I bought more when they were on sale for $10:
https://www.homedepot.com/p/DEWALT-10-Compartment-Deep-Pro-Small-Parts-Organizer-DWST14825/203367153
You will have to mod it a little for the ratchet, everything else should fit.
Old 06-09-2020, 04:32 PM
Sorry i should have said what was wrong: one clasp is gone, the other is real thin, the hinges are on their last legs. Injection molded plastic. I guess i could weld a metal frame for the holders... hinge, etc. seems like a lot of work though.
These are my small travel sockets for stuff away from garage. Ive got tool boxes but little things like drivers will get lost. I hate pawing through a bag of sockets.
Theres a ton of little pieces in there and its great to have all the sizes in order. Its pretty handy.
Im a super 3d printer skeptic but this might be a reasonable use for one. I couldn't care less about the window. Wish i could just buy another one, lame injection molded thing lasted a good long time. Theres lots of bad solutions for this.
Prolly theres something available deep on ali baba. I know... ill have my sons look.
Old 06-09-2020, 06:36 PM
vash's Avatar
Yea. cantdrv55 gave me a travel kit that I cherish. It’s saved my butt so many times. I treat the container very gently.
poof! gone
Old 06-09-2020, 08:35 PM
Unregistered
sammyg2's Avatar
Any info on make/modelbrand?
Maybe somewheres on the great wide webs there's an identical one fer sale that isn't all busticated
Worth a shot.
Old 06-09-2020, 10:29 PM
Almost Banned Once
sc_rufctr's Avatar
It really depends on how much you want to spend.
"Sortimo" is a German company and they make great boxes but they are $$$.
However you'd only buy it once and fill it any way you like.
(Search Google for "Sortimo". You can buy from their US online store)
For socket storage I like these.
- Peter
Old 06-10-2020, 09:44 AM
The Stick
RKDinOKC's Avatar
I use socket rails in my regular roll around tool box.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 06-10-2020, 10:11 AM
