Fleabit peanut monkey
I use scales and 30 lb tanks with the other standard equipment. I buy three tanks per year in a bundle buy and they cost about $80 per. You can't even buy the tanks anymore without an EPA 609 certificate. I will invert tank on low side charge for a few seconds at a time on a colder day. Probably wrong but no problems yet.
1981 911SC Targa Last edited by Bob Kontak; 06-14-2020 at 04:26 PM.. |
Brew Master
Nick |
Still Doin Time
Most modern mobile A/C systems are very efficient, very well designed and do more with less condenser area / evaporator area and smaller compressors. Speaking of compressors most all are variable displacement with a 'swash plate' where the displacement/ volume can change instantly and almost infinitely on demand.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
I remember the first car I attempted to charge with r12. It was a '63 Jag XJ6. I as delighted to find a can of r12 at the FLAPS so I went into it head strong and stupid. That was a piston type pump and I hydrolocked right off the bat. Scared the crap out of me. It was a long time before I ventured into that foray again. I bought some gauges a few years later and still have them. They are not high pressure enough to handle the refrigerants of today. Reworking them cost as much as a mass produced import set sells for today. Plus I have all the adapters now. Just have to purge a bit between types. |
As I only work on my own AC systems and time is not the main concern. I always charge with gas only. I have always been too chicken to try the liquid. So what if it takes me a extra few minutes to charge the system.
With the 911 I get crazy overkill trying to get all the moisture out of all that hose and 4 condensers and the evaporator. The Receiver Dryer is usually replaced if I open the system. So I vacuum and let it sit overnight. Then fill with dry nitrogen, vacuum for two hours, fill with dry nitrogen, vacuum again and let it sit overnight. If the pressures are the same, fill with refrigerant and done. Three days to charge a car is not a viable commercial operation. There are some cool videos on the internet of ice forming in a vacuum. Instead of the water boiling off, it turn to ice and can stay in that form for a long time. A few cycles of nitrogen and vacuum should eliminate it all. It is a belts and suspenders thorough way to make sure.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thread Tools | |
Rate This Thread | |
