I got this one recommended by the mechanic. LIke I said, I don't know too much about diesels. My thinking has always been bigger and more filter is better but he said this was more then good enough for what I need. I bought it to save my injectors. Before I bought the truck the old man that own it has injectors changed and the truck is bone stock but I wanted more protection. I lefe the stock filter in place. I am told it can be rid of but no reason to spend more money to to so. What ever has been through the Fass filter will go through the D max stock filter like a sieve. Good thing about the Fass filter is it cycles the fuel continuously as you drive. I tel ya, its hard to find a good diesel mechanic around here. |
Also, there are other out there like Bullydog (I think). To me, if they can use this for a class 8 trucks, its good enough for me ( they also make bigger and better filters for commercial OTR trucks and equip). I wanted this because I have plans to drive my truck up to Alaska in the up coming years. Its breaks down, I am going to have a very unhappy wife, so its worth it for me to do this. |
Yeah there are lots of brands of lift pumps available , I am surprised how pricey they are . They are just an electric fuel pump and a filter holder . I suppose like anything else you get what you pay for .
Final update 😁 . Went out this morning to see how the old gal would start cold . Cycled the glow plugs once and hit the key , she sprung to life like she usually does . So I am claiming victory on this issue .
I have talk to so many that think a lift pump should have been installed at the factory.
at 175,000 miles, are you still on original injectors. I know they are a pain to get at with your year and they go out. I even have a filter magnate around the stock filter to catch metal particles. |
Everything I have read say's the Kennedy pumps are rock solid and very reliable . Kennedy sells install kits and I already purchased ( a few years ago ) a single head filter base . Don't need an additional water separator because I will retain the stock filter/separator .
![]() I had someone else install mine. If I were to do it, the truck will rot out before it gets installed. |
