Home of the Whopper
Looks like a lot of work!
But should be worth it when done. If you properly size the AC unit you won't need a dehumidifier. Biggest mistake with a dx unit is over sizing it. Error on the smaller side so it runs more and wrings the moisture from the air. |
The 9 Store
The building is 20x24 and will be insulated at the attic rafters so the 2nd floor will be conditioned. I was planning on using a 12,000 btu, 22.5 SEER. Too big? Would the 9000 btu sized one be better?
All used parts sold as is. |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Home of the Whopper
Rule of thumb is about 600 sq ft per ton.
Are you putting soffit venting in? And spacers behind the insulation? And a ridge vent? |
The 9 Store
Rule of thumb is about 600 sq ft per ton. Good to know.
Are you putting soffit venting in? Yes, already there And spacers behind the insulation? Yes. I did that in my house attic reno. I know it's important. And a ridge vent? Yes, already there.
The 9 Store
Will do. Thanks
Edit - Just ordered. Thanks
All used parts sold as is. Last edited by mepstein; 07-26-2020 at 07:41 PM.. |
AutoBahned
use bleach first - rodents and their scat can carry many diseases
and wear a good mask when working until then |
The 9 Store
Selfie pic I have a garden sprayer that I’ll use to wet it all down with bleach and then use the odor eliminator once I vacuum up all the debris.
All used parts sold as is. Last edited by mepstein; 07-27-2020 at 03:15 AM.. |
