-   -   Unconventional bolt - please help identify (http://forums.pelicanparts.com/off-topic-discussions/1068830-unconventional-bolt-please-help-identify.html)
Tidybuoy 07-31-2020 11:22 AM
looks identical to the bolts that came with a toilet wax ring I just installed. You could probably find these bolts at a hardware plumbing section
http://forums.pelicanparts.com/uploa...1596219699.jpg
FPB111 07-31-2020 02:23 PM
Trailex also uses them to hold most of their aluminum trailers together. Drill a hole in your anvil and hammer a hex bolt head flat then file/grind to fit.
Also
https://www.rockler.com/t-slot-bolts-pack-of-five-1-4-20-thread?country=US&sid=V91040&promo=shopping&utm_so urce=google&utm_medium=cpc&utm_term=&utm_content=p la&utm_campaign=PL&tid=pla&gclid=Cj0KCQjwgo_5BRDuA RIsADDEntSo-BjBVN3dzt6yPHelx48C3sl6QhHk6XwnOfodQRPO-QIYilrM05EaAks_EALw_wcB
Bob Kontak 09-02-2020 10:16 AM
Originally Posted by 1990C4S (Post 10967465)
Those look like resistance weld studs to me, they should maybe have be projection welded into the door about 100 years ago....
There are absolutely weld marks where the original weld studs were positioned.
However, the only stainless acorn nuts were 1/4-20 at Lowes, so brass toilet bolts for the win.
http://forums.pelicanparts.com/uploa...1599066886.jpg
http://forums.pelicanparts.com/uploa...1599066909.jpg
http://forums.pelicanparts.com/uploa...1599066940.jpg
Tidybuoy 09-02-2020 10:32 AM
New, I hope
aschen 09-02-2020 11:10 AM
I love me some home depot engineering.
Scott Douglas 09-02-2020 04:40 PM
Dad's old '64 Travelall had mirrors a lot like that on it.
Had three gas tanks @60 gals total, split rims, it was a 1200 series.
They don't make them like that any more.
notmytarga 09-02-2020 05:56 PM
Beat me to it, by a month - toilet bolts is what I thought as well. http://forums.pelicanparts.com/uploa...1599094527.jpg
Those non-wax rings are great. Reusable and a more secure seal. The void in the base of the toilet makes a good hidey hole. These rings make it simpler to use it.
Nostril Cheese 09-02-2020 06:05 PM
T bolt or Trim bolt.
