-   -   Unconventional bolt - please help identify (http://forums.pelicanparts.com/off-topic-discussions/1068830-unconventional-bolt-please-help-identify.html)
Bob Kontak 07-30-2020 12:21 PM
These oddly shaped flat flange headed bolts hold the big mirrors onto the side of this 65 International I am sprucing up. Any idea what they are called so I can source a handful? I am missing a couple and need eight. Acorn nuts should be easy to find.
http://forums.pelicanparts.com/uploa...1596136822.jpg
http://forums.pelicanparts.com/uploa...1596136839.jpg
1990C4S 07-30-2020 12:28 PM
Those look like resistance weld studs to me, they should maybe have be projection welded into the door about 100 years ago....
csapp05 07-30-2020 12:31 PM
T-bolts
Aerkuld 07-30-2020 12:37 PM
Yup, what he said ^
Tee Bolt 1/4"-20, 20 PK (more choice) - POWERTEC
Shaun @ Tru6 07-30-2020 12:40 PM
This style of bolt slides into longhood aluminum bumper trim and then through the front and rear bumpers.
NY65912 07-30-2020 12:45 PM
You could probably use an elevator bolt if you can't find the exact replacement.
Bob Kontak 07-30-2020 12:51 PM
Yep. All good, my friends. Thank you. This should be easy.
Thanks for the link, Aerkuld.
Sooner or later 07-30-2020 01:01 PM
If you have a local Fastenal they probably have them
Bob Kontak 07-30-2020 01:02 PM
Those look like an option as even the "perfect" t-bolt will have to be subjected to the bench grinder to fit the top of the door mounting location. Thanks.
Bob Kontak 07-30-2020 01:15 PM
What a coincidence. My landlord worked at Fastenal for years and he just came to the shop. "Steve' come here and look at this. Would Fastenal have these in stock" He says, not in stock. "That's a weld stud and you can get them at any welding supply house."
Nice!
LWJ 07-30-2020 01:20 PM
More pictures of the International. I have a 63 in my side yard now. Grandpa bought it new. 30K original miles. Looked good until the barn fell on it.
Tobra 07-30-2020 01:38 PM
Sort of like the stud version of a captured nut
GH85Carrera 07-30-2020 02:19 PM
When a stud like Bob works on it, it is the stud version bolt. :eek:
Bob Kontak 07-30-2020 02:37 PM
How cool is that? You really want to get me started, lol? This one has about 15k on it. Was a fire station truck It's the 4wd, D1300. Can't hit 50 mph on the freeway.
http://forums.pelicanparts.com/uploa...1596143326.jpg
http://forums.pelicanparts.com/uploa...1596143349.jpg
After five months in shop (among other projects).
http://forums.pelicanparts.com/uploa...1596143441.jpg
22 holes in roof plugged with weld (professional welder, and I held the brass rod inside the cab) and many peeps (across time) on hands and knees installing and repairing sirens/lights.
http://forums.pelicanparts.com/uploa...1596144403.jpg
Filler primer after epoxy.
http://forums.pelicanparts.com/uploa...1596144517.jpg
Washing etching acid out of interior.
http://forums.pelicanparts.com/uploa...1596144560.jpg
http://forums.pelicanparts.com/uploa...1596144611.jpg
Before any wet sanding
http://forums.pelicanparts.com/uploa...1596144642.jpg
Some sanding and polish
http://forums.pelicanparts.com/uploa...1596144673.jpg
http://forums.pelicanparts.com/uploa...1596144708.jpg
Bob Kontak 07-30-2020 02:39 PM
Front thingie back from powder coater.
http://forums.pelicanparts.com/uploa...1596145114.jpg
Inventory tag in door jamb. Spots are polishing compound.
http://forums.pelicanparts.com/uploa...1596145136.jpg
Tobra 07-30-2020 02:39 PM
Is this a Chuck Norris thing?
Bob Kontak 07-30-2020 02:49 PM
He meant "When a spud like Bob works on it"
LWJ 07-30-2020 05:20 PM
Sweet!
Thanks!
LJ851 07-30-2020 09:34 PM
Bob, that's a great truck, is that yours or for a customer ?
We should have an IH thread around here, i might have to start one...
Bob Kontak 07-31-2020 08:59 AM
A customers but more a friend than an arms-length customer.
Quick story. I broke the passenger door window when gutting the door. I freaked out. Found an IH salvage place in Washington state. "Is there any way to get another window?" Guy says "Relax, I have 50 of them in the yard". They are all the same regardless of model across many years. Phew. $80 - Sold!
