Make Bruins Great Again
Help Identifying 2 different ammo cartridges
Found these at the range recently. Any help would be greatly appreciated.
The first is 9 mm and marked Win (Winchester) but I can't find any info online that would indicate what kind of bullet it is. ![]() The next one has be totally baffled.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Well it helps if I post the pics
I see you
The first has the look of a polymer coated bullet but we need Mr. Higgins.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Polymer coated bullets are getting pretty common these days. It's a pretty cheap and effective way to apply a "jacket" of sorts. Some companies supply loaded ammo with them, some sell them as component bullets for reloading. There are even kits to apply it yourself, at home in your spare time, to your own cast bullets.
It looks like the bottle necked case is either a 7.63 x 25 Mauser, as used in the old Broomhandle and other pistols, or the 7.62 x 25 Tokarev, which was the Eastern Bloc military pistol caliber through most of the Cold War. I think they are pretty much interchangeable, but don't quote me on that.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Thanks for the info. The polymer coated bullet threw me off because I couldn't find anything Winchester made that looked like that. It makes sense that there are bullets sold for reloading that are polymer. This is prolly a reload.
The second looked like an old cartridge and like nothing I had seen. I'd like to know more about what pistol shoots this round.
![]() The proportions seem off for 7.63X25 Mauser. Maybe it’s just the angle of the picture.
1971 R75/5 2003 R1100S 2013 Ural Patrol 2023 R18 |
I'll go with the 7.62x25... Very common to split the case with them...
Polymer coated bullets can be bought through the bulk warehouses now...
dolor et pavor Copyright |
As a result of this, bottlenecked rifle cartridges usually look substantially the same after firing, with the upper and lower edges of the shoulder maybe looking a little sharper and better defined as the pressure of firing forces the rounded corners into the sharply machined chamber profile. That shoulder cannot move, however - the shoulder on the unfired case has to make contact with the shoulder in the chamber to control headspace. Bottlenecked pistol cartridges, however, do not have that requirement if they headspace on the mouth. As a matter of fact, manufacturers will often place the shoulder in the chamber quite a bit further forward than it is on the case, providing a good deal of clearance to ensure easy chambering. When fired, then, the shoulder on the case is moved forward to fill that area in the chamber, thereby shortening the neck on the case. I used to put up with that crap when I was loading and shooting .38-40 and .44-40 Winchester in Colt single actions. These are both bottlenecked rifle rounds, meant for the Winchester 1873 lever action. Colt chambered them in the single action, so guys far away from ammo resupply could feed both rifle and revolver the same ammo. These headspace on the rim, just like any other rimmed cartridge. The "bottleneck" is very indistinct on new, unfired brass. It gets very distinct after firing, and moves forward a noticeable amount. Here is a great picture that I found that illustrates this. Unfired .38-40 on the left, fired on the right: ![]() I think that might be what we are seeing here with this auto pistol case.
Wow awesome info. Thanks
Thanks, guys, for consistently posting stuff like this. I always learn something here.
A Man of Wealth and Taste
Circle 21..is Russian Tokarev..
