What is the cost to 3d print things?
Like the nylon pieces in the door striker? I've replaced a bunch but it seems only the bottom piece goes bad.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Super Moderator
$200 for a capable machine and how Ever many hours you want to invest.
Material,costs are negligible. I fixed our washing machine for $0.27 in material now that I kNow what I’m doing after 100 hours of experience.
Information Junky
The trick is that you need a 3D (CAD) model of the part.
Then send that to a print service. I have a favorite for nylon parts. (super cheap, unless you need 2 day turn.) Any place with an SLS or an MJF printer will do.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Platinum Member
These?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Information Junky
Oh.... those...
is the door breaking where the catch pin hits, or wearing the lower?
There are a plethora of 3D printing services available, from the type of stuff you are looking for to really high end stuff.
We use these guys quite a bit: https://markforged.com/ Incredible stuff. Very inexpensive service compared to staffing this type of capability ourselves. Most 3D folks can also scan if you don't have the CAD.
1996 FJ80. |
Slackerous Maximus
If someone has the drawings, I can print them in PLA or PETG.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Information Junky
PLA Nooo....
PETG Yes! I can't help but want to redesign that lower for a better strike zone. An FDM printed version would make a tough strike zone if done right. If I find the time, Ill send you (HD) a file that you can print and send to Bryan.
Slackerous Maximus
PLA would not be a good material, truth. Frankly PETG is questionable as well, but certainly better than PLA. I can hypothetically print in ABS, but I have not tried it before.
Retired, finally
Can someone make the clamps to hold on a Targa hard top? One of mine is broken. I haven't looked to see how hard removing them would be.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
In the category of useful info: Printing Flexible/ squishy stuff. I did have success with TPU. I made a carb boot that allowed me to adapt a 38m Lectron carb to a Boyesen Rad valve intake on a big bore CR 125 project. ![]() I used SainSmart TPU https://www.amazon.com/gp/product/B00TI3JUVA/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 It was one of the higher durometer TPUs and I had no issue feeding. My 5 min of research found that the really squishy stuff needs a direct drive head.
"The primary contribution of government to this world is to elicit, entrench, enable, and finally to codify the most destructive aspects of the human personality." Jeffrey Tucker |
Information Junky
TPU will turn to crap. It may be a few years, but...
I find that printing ABS is easier than PETG. The mistake many make is in trying to run too fast. PLA squirts like butter... toothpaste? Anyway, a bit more heat and slow it down and ABS should be fine. Its all about finding the right settings.
Super Moderator
Check out thingiverse.com
I’ve found so many bits I needed there. It’s like the library of Congress for 3D designs. I’ve designed several commercial products with zero cad experience.
Super Moderator
Information Junky
Mine has a heated bed and is an open design (a MagerGear M2)
My early ABS experimenting I thought the tip was clogging, but really it was the extruder pushing hard enough that it would machine away the filament, and no longer grip and feed. If the problem is peeling/curling off the bed, then yeah, that's a "draft" problem.. or at least the base cooling off too much.
That's it! What about you guys? Do the tops and bottoms of yours go bad, or just the bottoms?
Platinum Member
If the extruder is stripping(too hard to push) try turning up the nozzle (hot end) temperature.
ABS really should be printed with a enclosure to maintain temp in the chamber.
Alternatively you could try ASA its similar to abs without a lot of the printing challenges associated with abs. I have a pretty modified ender 3 pro. Probably will be building my own dedicated printer to print more structural and useful parts over the winter.
1976 911 1976 914 1986 951 |
Hell Belcho
There has to be a few maker spaces in HI somewhere. Go find one of those and ask the people inside.
Got tons of friends making piecemeal stuff for under $20.
Saved by the buoyancy of citrus. |
Information Junky
Bryan - I have not had a problem with those breaking. I don't think... I'll check.
I also was thinking about some may have issue with their hotend not actually being at the temp they think it is. Others tell of set-up temp's but really there are a lot of variables there, including how the software handles the lag in temp sensing/heating. To damp the heat/sensing swings (and inherent lag) I've added extra insulation to the hotend and tip.
