Team California
Fog lights:
I bought some fog lights I've been wanting for my PU truck and they arrived without any additional wiring or switch. All good, they were cheap and I don't mind wiring them. Easy job.
My plan was to wire the positive directly to the batteries of the truck, which are about 12" away from where the lights will be mounted, and then wire the ground through a toggle switch on the lower dash, with maybe an inline fuse on the positive side. Any flaws in this plan? I never wire added accessories through existing wiring or switches, it's so much easier and safer to wire them directly. TIA.
Denis Last edited by speeder; 10-02-2020 at 08:14 AM.. |
Team California
The lights:
![]() ![]() I can double check but almost certain that they are 55w bulbs.
Denis |
Not sure about inspection in your state but some states don't allow the fogs to work when high beams are illuminated. May want to consider wiring them through the headlight switch with a relay.
Team California
There is zero chance of wiring them through the factory headlight switch, (which would not even prevent them from being used w high beams). They would have to be wired through the turn signal stalk, that controls high/low beam. EDIT: Which is probably wired through headlight switch(?)...I see what you mean. Any input on my wiring plan? Is it solid from an electrics standpoint?
Denis |
I would use a relay with the low beams. There are kits out there for it.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Hell Belcho
You should use a relay in the circuit. Plenty of wiring diagrams online to look at. Google aftermarket fog light wiring diagram.
Saved by the buoyancy of citrus. |
I would have thought you'd want a relay so you don't have the current going through the switch, but maybe I'm wrong.
I would want a way to turn the lights completely off, not necessarily so they are always on when the low beams are on, although that's not as big a deal with fogs as it is with driving lights.
Yes, I wasn't clear in my post. It also can have them unpowered when the headlights/parking lights go off so you don't forget.
Fuse it. Beyond that, whatever you want to do.
I would be inclined to use a relay driven from something that powers off with the key, but a decent switch will handle that current no problem.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Team California
Do you mean the toggle or flip switch I plan on installing for the lights? I was planning on having only the ground wired through that switch. Is that the same as having power going through it, as far as amperage to the switch? I'm not an electrical genius but I always wire things like this in their own circuit w a fuse. Can't go wrong that way.
Denis |
Team California
These fog lights absolutely need their own switch, independent of the factory headlight switch. Are you guys recommending that they are wired through the headlight switch solely to have some sort of *lockout* function where they cut off w high beams?
Denis |
Team California
Oh yeah, they're yellow.
Denis |
Hell Belcho
A relay typically has four terminals 1. 12V from battery 2. Ground 3. Switch or trigger wire 4. Output... (lights, etc..)
Team California
Ok, I'll get a relay. Thanks.
Denis |
( with maybe an inline fuse on the positive side.) You absolutely need to put a fuse on the positive side battery rated to the wire, and right at the battery.
87 930, |
Team California
I’m at the auto parts store right now and don’t know which switch or wire to buy. I did get a relay w the correct terminals according to instructions that came w lights.
They sell a 15 amp switch, 20/25/30 also. I have no idea what it needs. Also, what gauge wire and how big of an inline fuse? The wires coming from the lights are surprisingly wimpy, maybe 18 gauge? Thanks. ![]()
Denis |
How many watts are the bulbs? 60w 100w?
87 930, |
If you are using a relay a 15A switch is fine, it is only turning on the relay, a 20A relay should be fine for up to 2 x 100w bulbs. I think 12ga wire should be good, 20A fuse. You can use the smaller wire for the switch to turn on the relay but put a 5A fuse on it.
The best way would be a relay for each side and then use smaller fuses and smaller wire size,
87 930, Last edited by 908/930; 10-02-2020 at 10:59 AM.. |
D idn't E arn I t
Here’s a really ugly diagram I made just for you
-5 prong normally closed relay. Don’t say I never helped a fellow Pelican. Low load on toggle switch. Grounded. 87 to bat + 30. positive (+) on light, neg on light to any ground 85, + switched power 86- toggle switch to ground. 87a- leave open. Ur welcome. rjp
