Buying junk tools
When making nearly any purchase, from a spatula to a welder, I research the hell out of it and then pretty much buy the best one.
I have to break up 12 x 25 feet of asphalt that's about 4 inches thick. I can buy a proper barely used Hitachin on CL for $400 or something like this for $165. The Hitachi I'd have to sell which would be oh so much fun while the Mophorn would just sit in the corner. Rental is $90 per day and between going to get it, use it and return it, I've spent $200. Mophorn 3600W Electric Demolition Hammer Heavy Duty Concrete Breaker Which would you get?
Tru6 Restoration & Design |
Platinum Member
Asphalt? None of the above. Find a guy with a backhoe or skid steer and have him peel it up.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
The Hitachi on CL would probably be best. It wouldn't be too much trouble to sell it. If you need it hauled away, getting a guy like dad 911 suggests would probably be best but cost more than $400.
Marv Evans '69 911E |
Breaking concrete is only used when there is rebar and then you can lift up some big sections and cut the exposed rebar. Asphalt never needs to be demo'd with a jackhammer. |
Hitachi? Yes, but with a wide blade, or you’ll spend all day chipping it up. Of course, then you have to pick it up, load it and take it somewhere.
Go with Dad911’s idea. |
I think you need something bigger then that Morphon. You will be doing the demo on your knees. Try and get a stand up jack hammer. I recommend renting.
A Man of Wealth and Taste
Why not get a tiny little rock hammer and chip away at it over the next 20 years..then when finished head off to Zihuatanejo
Copyright "Some Observer" |
Best method I think, from experience would be to use a gas powered demo saw and cut 2' wide strips then pry them up flipping them over.
UnRegistered User
I can't make it on the outside, Andy. I've been institutionalized...
Few big blocks of wood and a 6 foot prybar and a sledge hammer will be faster than using that little breaker.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Platinum Member
Good replies. The asphalt is soft, a big chisel with a 2.5# sledge goes right through it. There is an open edge that has already California'd and easy to get under so I'll try a 6 foot pry bar first.
Couple of places on CL that will take it away. 60 in. Pinch Point Bar
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 10-11-2020 at 05:54 PM.. |
You do not have permissi
I agree a backhoe would probably be overkill for such a small area of repair.
What is the intended final result? To put in a lift outside? Repave a section buckling from roots? Does it have to be a clean edge result or just done?
Meanwhile other things are still happening. |
Can you rent and get one of those Toro Dingo's back there? I bet that would peel that up in no time.
Something like this: https://arapahoerental.com/equipment-rentals-product/walk-behind-loader-diesel-toro-dingo--mt55-bobcat/3428 |
Yes but I don't think it will be necessary. Going to HF today for the pry bar to see how easy it will be to lift up. I almost think my 4X rivet gun would break it up.
Brew Master
I'd use this with a set of forks. Weighs about 3800 lbs. Setup with wide tracks, it barely leaves a mark in grass provided you don't take any sharp turns. Has an 850Lb R.O.C. and would make short work of the job. Half day rental wouldn't cost much more than the tools you're looking at buying and would save you a LOT of grief. Plus if you rent a dump trailer to haul it in, you can load the asphalt into the dump trailer and dispose of it.
Nick Last edited by cabmandone; 10-12-2020 at 04:31 AM.. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Brew Master
Nice thing about the MT85, a Vermeer S925TX or the Toro models is that they use Joystick control so you use one hand for steering and the other for bucket and boom controls. The smaller MT55 has sort of a strange control for steering so it's harder for a novice to operate than the joystick machines. Plus I like the larger models that you stand on rather than walking behind or riding on a roller platform.
I like "work smarter not harder" so the mini track loader would be my choice for the job in this thread.
Nick |
Posting may have been unnecessary. Talking with asphalt disposal guys, 2 say they will dispose for $500-600 but both will do the entire job: rip it up and dispose for under $900. Seems like a no-brainer. Both coming to look at it.
Asphalt is very soft. Hitting the edge with a sledge hammer crumbles it. A pick would work very well too.
Brew Master
Definitely a no brainer! At that price I wouldn't do it and I own most of the tools to do the job.
Nick |
That's always the problem that I have here...where to dispose of dirt, concrete, asphalt or anything similar? We have no landfills open to the public.
I had a similar sized section of my asphalt drive replaced last year. I remember watching them scoop up the old with a bucket loader on a tractor. There weren't very many pieces that stayed large...they all crumbled.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 10-12-2020 at 10:12 AM.. |
