a car question! the Check Engine light.
well, DUH!! the other day, the CEL came on in my wife's Subaru. it was alarming to say the least since we were far from home. car seemed to run fine.
when i got home, i took the time to think about "what has changed?". it hit me. i changed the engine air cleaner because everything up here has been sucking in sooty smokey air. (filter was black!). i neglected to close up the airbox tightly, and inadvertently left a corner unclipped. i hooked it all down correctly, double checked, triple checked..and disconnected the battery. upon start up..no CEL! that it? done? how does an aftermarket cold air intake not trip the CEL? i was shocked a tiny bit of air whizzing past the element would trigger the CEL.
poof! gone |
Dog-faced pony soldier
It’ll go away until you’re in a bad neighborhood late at night to maximize irritation and paranoia (or right before a vehicle inspection check), then it’ll come back.
Driver, not Mechanic
A reset sometimes clears the faults. On my Sienna for some reason the VSC system warning light lit up while on the freeway. Having done nothing to the car nor have I used it on bad roads in the last 3 months, I simply disconnected the battery for a few minutes (or more precisely just the black wire), hooked it back up, and warning is cleared. Have driven it a few times and no issues so far.
On the other hand, my Cayenne first showed a "reduced engine power" light. And now it's a CEL. Car runs fine, unless you try to accelerate. Probably in limp mode and running on 4 cylinders. Since the battery is under the driver's seat, I wasn't going to bother, but will take it to an indy for diagnosis. The only two things I did were: 1) I tried to jump start the 911 with the Cayenne while forgetting to start the Cayenne first (stupid move) and 2) I put Techron complete fuel system cleaner a week ago. This might be more of a coincidence. But it could have exposed some part in the fuel system that is nearing its end of life, like the fuel pump. |
Brew Master
Plug a code reader in and see what codes are stored.
Nick |
Make Bruins Great Again
You can borrow a code reader for free at the FLAPS and they'll tell you what the code says. Some of them have a reset (if you read the manual) but they won't tell you how to do it.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
The check engine light is the most reliable part on a BMW .
No left turn un stoned |
That, and your gold Mastercard to pay for maintenance and repairs.
The wife’s 2002 Camry loved nothing better than a new gas cap to get rid of the CEL.
I think the dealers are able to automatically engage the CEL whenever their service revenue dips for the month. |
Still Doin Time
^^^^^^^possibly the best quote in awhile........I'm filling that one away. Especially any 'M' car.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
You do not have permissi
Some auto part stores will check for stored DTCs for free.
They plug in a scanner. Read stored trouble code. And then suggest the correct muffler-bearing lube. The dash light probably won't come back on until drive cycles are completed. If at all. Until then, check all fluid levels and filters for condition. Drive normally. Watch gauges.
Meanwhile other things are still happening. |
Pre-1996. (There was a 1994-1995-1996 overlap with Canadian made vehicles IIRC. My 1995 Legacy was OBD2.) MIL (Malfunction Indicator LampLight) is OBD2. Anything after 1996. It incorporates everything including transmission powertrain, intentionally self-testing systems by activating EGR to look at O2 sensor response, ABS sensors, and all the nonsense. The drive cycles have to complete over time. Start-stop. Freeway. WOT. Cruse. Braking. All of it. It is probably different for different mfrs. The short-term long-term fuel curves also have to be set. MIL is the correct terminology to use.
Meanwhile other things are still happening. Last edited by john70t; 10-20-2020 at 07:26 PM.. |
Fleabit peanut monkey
All OBD codes were cleared and the monitors were reset when the battery was disconnected. You are starting from scratch. Your car has to run the self checks. It can take a while.
1981 911SC Targa |
I can go 60 mph on I77 for six minutes but have to find an uphill grade and put the car on the shoulder to slow down to not end up as a grease spot.
1981 911SC Targa |
FLAPS???? Battery???
Buy this cheap Chinese bluetooth OBD reader: https://www.amazon.com/gp/product/B00PJPHEBO Put Torque on your phone. Then pay for Torque pro. You can now get your own codes whenever, clear them, and see why they're there. You also know if you've put enough miles on to pass emissions after clearing the codes. You also get fun little gauges for all sorts of things that your car doesn't tell you right now.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
For 13 bucks I just ordered it... I'll check the Torque app later.
Brew Master
I loaned my old Subie to my nephew once. The CEL was always on. He calls and says "The check engine light is on" I tell him "Pop the hood". He says "Okay" I say "is the engine still there?" He says "you're an ass"
My favorite CEL illumination comes from the gas cap not being on tight. That's not the engine!!
Nick |
Still here
Throwaway Chinese readers might be infested with permanent CCP apps.
I suggest getting the standalone model specific scanners. They pay for themselves after saving one trip to the shop. |
I say nut up and buy a slightly more expensive reader with Parameter ID's. The CCP version is probably $50. An Actron at your FLAPS is $250.
1981 911SC Targa |
Evil Genius
yes quite often I check under the hood, and the engine is still there.
Life is a big ocean to swim in. Wag more, bark less.
Still here
https://www.icarsoft.com/Product/s-299-iCarsoft_MB_V1.html |
