Anytime I have a belt off for other maintenance, I just replace them. But they are just fan belts and cheap not serpentine belts. I also change the brake fluid on the Elky every other spring, and the 911 every single spring. The antifreeze on the Elky is changed every other year, I have yet to find the drain plug for the antifreeze on the 911.
I am a big believer in preventative maintenance. The Elky has 372,000 miles and has stranded me once when the torque converter shaft snapped off. The transmission shop guy said that in the 40 years of working on transmissions the only broken shaft he had seen was a kid doing neutral drops. Mine was just a defective part that he warrantied. He know I was not doing neural drops.
Old 02-19-2021, 06:28 AM
Brew Master
cabmandone's Avatar
Two Porsches stacked and a Honda Fit LOL!!!
Nick
Old 02-19-2021, 07:38 AM
^^^ That was the day before I asked "Where's Old Man Winter"
The Prelude is in there also...yesterday was the first day out for that. (Because of the Fit's belt)
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 08:42 AM
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 08:46 AM
I'd say that you got your money's worth. I've never run one even 100,000 miles.
Old 02-19-2021, 09:10 AM
Brew Master
cabmandone's Avatar
You take the turtles for rides in the 911's so they know what it's like to go fast?
Nick
Old 02-19-2021, 09:13 AM
^^^ Yep..they insist on Targa's for the sun.
A pic of the serp belt. It's only a 5 ribber and I expected to see it frayed badly.
Looks like it just gave out.
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 09:26 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Only the young ones. The older ones he just stops paying attention to.
On a serious note, just talked to my landlord about the 200k mile 2005 Odyssey I bought from him that he bought new. "Steve, when did you have the timing belt changed?" He says "I never did".
1981 911SC Targa
Old 02-19-2021, 11:40 AM
^^^ My Prelude was 50K over on mileage for the timing belt replacement.
Last year, when I had it done, the old belt looked just like a new belt. I asked the tech about that and he said "I have seen them break when they look just like the replacement ones." "You never know"
I feel better now...knowing that I won't have to do it again.
turtles enjoying the winter..... (There's a young one buried underneath the others!)
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 11:59 AM
Originally Posted by Dantilla View Post
I replace belts and hoses at 100k and keep the old belt as a spare.
My Jeep is about to hit 200k, time to replace them again.
I never could understand that logic? If you are replacing anything because you think it is near the end of it's life expectancy why would you keep it as a spare?
Why would you put the old one back on just to go get a new one to take the old one off to put a new one on? Plus in the time it is being used as a back up don't you run the risk of it failing? That's why you took it off in the first place.
Why not just buy two new ones and keep a new one as a back up and do the job once?
Old 02-19-2021, 01:03 PM
Bob Kontak's Avatar
I posted a thread about some shaking while driving which is probably the driveshaft(s). From that thread a kind member here sent me some new KYB struts he had but never installed.
There's going to be a couple days of that beast on the lift very soon and once I drive it under the lift arms there will be a moment of prayer to the higher power for allowing it to journey that far on that timing belt.
1981 911SC Targa
Old 02-19-2021, 02:39 PM
^^^ Until you get it in for the belt replacement, (unless you are doing it yourself) I would refrain from full throttle snap starts!
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 02:48 PM
Bob Kontak's Avatar
Pulled the trigger ten minutes ago on a complete kit (w/water pump). Clearing the slate for a Thursday start.
Only way I would do full throttle blips is if I had nitrous oxide. Who puts that on a Honda?
1981 911SC Targa
Old 02-19-2021, 05:34 PM
^^^ Nice that you can do that job yourself.
I watched the procedure on youtube and realized it was way too much for me.
I've never seen it before...but I'm sure a Zex kit would fit on an Odyssey
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 06:05 PM
Bob Kontak's Avatar
You did a MacGyver on the serpentine belt with that piece of wood. You could handle a timing belt.
It's a little scary the first time but it is very straight forward. I'm still always nervous but one probably should be.
1981 911SC Targa
Old 02-19-2021, 06:47 PM
Just thinking out loud
mattdavis11's Avatar
Timing belt life has become much better since hydraulic tensioners. However, it is rubber, and can rot, swell etc.. due to water/oil leaks and age. I have 207K on the belt I replaced on the Camry, looked new at 155K. I'm not sweating it.
Throw in a balance belt and my position changes.
91 FJ80
84 Ram Charger (now gone)
Old 02-19-2021, 09:57 PM
I change all the belts every timing belt change on my Tacoma. I have done it four times. No too hard of a job..... still don’t know where the leftover 17 mm bolt went
Old 02-20-2021, 06:58 AM
What is this balance belt you speak of?
Does Honda use them also?
98 Honda Prelude
22 Honda Civic SI
Old 02-20-2021, 07:56 AM
My 944 and 2002 Honda Accord have a balance shaft belt. You can run with out them when you would like a massage. Harmonics. When they snap, timing belt is likely to go with it. Bent valves if an interference engine.
91 FJ80
Old 02-20-2021, 08:07 AM
^^^ Is your Accord a V-6?
My Prelude is a 4 cyl and I don't remember ever hearing about it having one.
98 Honda Prelude
22 Honda Civic SI
Old 02-20-2021, 08:14 AM
