Band.
Not really. Too many variables. These are bookshelf-size background speakers.
The basic answer is "not very loud but acceptable for background music and an occasional announcement." Certainly not loud enough for every event, which goes to the suggestion before it about rentals or something.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
JYL:
Here's what I would do - Forget about your criteria. Seriously, you can't do anything with that set of requirements. 1. Describe who you're catering to. The budget, the expectations, size of event, what type of sound they want. 2. Ask for suggestions: gear, set up and tear down manpower, and budget. Also what type of revenue the system alone can add to the venue. 3. Will there be a change in the venue itself? In other words, future expansion, renovation, etc. I didn't want to comment on this thread because basically you're trying to "cheap out" on your solution. I have zero interest in going to a clapped out cheap ass venue that thinks it's a library but talks like a dance hall. |
The 85db thing is still a tough one for me, where would that be measured?
Inside in the middle vs just barely outside the door is going to be a 5db difference and 10' from the building itself a pretty big jump again, so maybe we are misunderstanding. Because as Gogar says, 85db just with a room full of people is easy to hit. db is also a weird scale to try and aim for sometimes because loudness doubles every 3db if I recall correctly.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
So maybe something like
1. https://www.rockvilleaudio.com/rcs350-612-wet-6w/ - a 350 watt 70-volt amp with IR remote + twelve 70-volt speakers with 6.5” drivers 2. https://www.amazon.com/dp/B085W1PPHL/ref=cm_sw_r_cp_api_glt_fabc_01JV5V1N3YH8ZXK2DYP2 - 4 into 1 RCA switch 3. adapter cables to RCA from USB-A, USB-C, HDMI and Lightning 4. https://www.amazon.com/dp/B07RJLKBRD/ref=cm_sw_r_cp_api_glt_fabc_AZH7WWEERCSWWXQJNFXV - Wireless mic system 5. https://www.amazon.com/dp/B018YHUE5Q/ref=cm_sw_r_cp_api_glt_fabc_NF5F87M3XNBPS2W3Z5DM - 500 ft roll of 16 ga speaker wire in white sheath Would total around $1300 ish, a little above my budget, but I wouldn’t need a separate PA system for the speeches etc. Seems very DIYable. Renter plugs in their iPod, phone, USB stick, laptop (most will use a laptop) using the appropriate RCA-to-whatever adapter cable, chooses the source on the RCA switch (or the manager helps them) - or they use Bluetooth - then voila they have sound for their event. No matter how they screw with the amp, they can’t get it too loud because we’ve tapped the speakers appropriately. If one half of the room needs conversation-level sound (i.e. lower) they can turn down volume for that zone (or manager does it). If they use the mic, the amp detects the mic signal and mutes/ducks the music by a user-selectable amount. If we need more speakers, like for the mezzanine, I can add more 70 volt speakers and zones. If we need more power, the amp’s line out can feed another amp which can drive more speakers. If we want speakers somewhere that is hard to reach with wire, the line out can feed a wireless powered speaker system. The speakers are not as sleek looking as pendants, but will be easier to install (getting to the ceiling requires a ladder of a height that I, as a matter of policy, decline to climb) and being able to aim them might be handy, and they are white so won’t be visually obtrusive. Rockville advertises a 90 day money back guarantee, which I’ll ask them about, but hopefully I can lay the speakers out on the floor and get a sense of whether they will reach 85 dB in the ballroom and generally whether the whole thing will work for us, and return it if needed. Sound good (pun!) to the brain trust? Oh, about the live band thing. I am not inclined to install anything to accommodate a live band or a pro DJ. Seems to me the bands and DJs can bring their own sound gear, I just need to make sure the electrical circuits to the stage are adequate. I just want to provide a basic sound system for the renters who are not hiring a band or DJ. Which is fairly common. We are trying to be an affordable wedding venue. Also, we’d like to get more fundraiser, awards, social party, business retreat, meetings, etc sort of events. Those don’t hire bands. (They often do need a good projector and screen, which is my next thing to figure out.)
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
There were other restrictions adopted to keep the peace, like ending events at 9 pm and limiting event size to 150 persons. We’ll see if we need to stick to those, but initially we will. We are the neighborhood association after all, so we are mindful of the nearby neighbors. I’m going to invite one of them to join the the committee overseeing the club’s operation.
Does the neighborhood association need a meeting place?
Do they have a budget? Where does their money come from? Maybe they'd like to share in the profits or want an annual contribution based on the dance hall's business? Have you met individually with the board members? Do you have a sense of what will splinter their voting group? 65dB at the property line is roughly the equivalent of a kitchen refrigerator at 2-3 feet. Does this ridiculous number apply ** ALL DAY ** AND AT NIGHT? If so, then the hall has agreed to go bankrupt so you can just forget it. |
In Portland, if you want to rent a venue of this sort, especially if you want a large dance floor, the choices are quite limited. Many of them are in areas of the city that, right now, look like hell - boarded up storefronts, sidewalks lined with tents, sketchy or deranged people wandering around, asking for money or being nasty because you have, presumably, a home and a job. We, being in a rather more pleasant location, won’t have any problem booking up. So far the hit rate is decent: from 10 email or phone inquiries, about 1-2 come tour in person, and of those, 4 of 5 end up booking. The rate of inquiries has been rising, as people start planning events again now that the light at the end of the Covid tunnel is visible. I think demand will be unusually strong in the back half of this year and probably next year. I’ve also found someone who is willing to manage the marketing and rentals for very little money, virtually free this year and not much after that. So my job is to get the place able to reopen in two months and at least break even for 2021.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 02-28-2021 at 11:41 PM.. |
^ I have dealt with those type of neighbors. I own and run a regional carnival.
I bought a calibrated Reed Instruments sound meter. The calibration tool ends all debate about accuracy. Decibels is a relative measurement. Not an absolute. For example, you must use the dB meter and a distance measuring device in order to get the relative sound level. You say 85dB at 40 feet. I think your starting point is to get some clarification regarding the sound level at a certain time of day at agreed reference points upon the property and then work back from there. No point in designing a system that can't be used. You need a vote and have that stuff written down. |
Band.
"dB measurements" are almost exclusively misunderstood by a fretful neighbor with a "dB meter."
The first and most often misunderstood is the 'weighting' of the reading. The measurement is taken with (most commonly) "A-weighting" and "C-weighting" of the reading. "A-weighting" applies a curve similar to the natural frequency response of the human ear, and responds less to low frequencies and very high frequencies. "C-Weighting" is more or less linear from low to high. The sound of people talking in a room "a-weighted" vs "c-weighted" would probably meter about the same, but Music played by a band in the same room, with some low end or a subwoofer could easily meter a 10 or 20 dB difference in level. Another problem with metering standards for these kinds of situations is "instantaneous" vs an "average over time." We dealt with this daily (back in the before time when my kinda work existed.) If you want to win the war of the meter then you need to just be knowledgable about 1. What 'weighting' is the reading and 2. If it's instantaneous or an average over a certain time. An A-weighted 10 second average reading of 85 dB could be quite manageable, whereas an instantaneous C-weighted reading of under 85 dB is largely unattainable, ever. JYL As far as your choices in Post #24 go, YES they are fine choices inasmuch as the kind of idea that myself and Mystic Llama were pushing. With the caviat that you have chosen basically the 'harbor-freight' version of every single component. No judgement, as long as you have the proper expectations. And, it's what you have to work with for your project right now. I feel like it might work out just fine.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 03-01-2021 at 10:21 PM.. |
Question - for this sort of thing, mono is fine, right?
Okay, interesting thing. I was introduced to a DJ who has been doing events in this club for 30 years, very familiar with the venue, sound gear needed for it, venue noise limits, type of events, etc. Older guy, he used to have multiple crews providing music to different events, also used to buy and sell pro audio stuff. Anyway, we’re going to meet at the club in the coming week or two. He’s going to give me some advice on the situation. “Harbor Freight” level of sound will be fine to me. I need to get this place ready to reopen soonish. Covid may of course intervene, but as of right now we have events booked starting end of April, and we want to honor those bookings. We’ve got carpet, landscaping, paint finish, drapes, all kinds of stuff to do, and a manager to hire. If I can spend $1-2K and get a passable solution that will get us reopened and making revenue again, that’s great.
Band.
Yes mono is common for things like installed 70v so that everyone hears the same thing across the room. If you play a Beatles record, for example.
That's great that you can talk to someone who knows the room. He will probably won't be too excited on a 70v install but it will be interesting to see what he suggests for 1k. He too will probably also suggest $5k. maybe some powered speakers on sticks or something more traditional
It is interesting - this club has been here for a century, has a lot of history, and many have warm feelings toward it. We've met a lot of people who want to help it to reopen, especially by a non-profit with a community mission.
