Always thought there should be some kind of "socket" one could plug a charger into for charging anything on wheels....cars, motorcycles, etc.
Seems like we are behind in technology on this.....
Old 03-17-2021, 05:07 PM
Bean counters are to blame for this? If its easy enough to lift the hood and clamp a set of jumpers cables, crank and be home in 15 then why install a plug in unit? Clamping a set of jumper cables to the positive side is a bear on my truck. No room and the bolts head is only 9mm. Too small to get a good bite with jumper cables. Now, Porsche take this to a new lever of complexity on their newer cars. I think there's a charging port down near the driver left panel to charge the electronic hood release. I discovered that the painful way.
Old 03-17-2021, 06:16 PM
wdfifteen's Avatar
EVs have one. Time for the oil burners to catch up.
Old 03-17-2021, 06:32 PM
Should we get rid of our tubs then?
Old 03-17-2021, 07:26 PM
I've noticed there are some jumper cable clamps that are better at this than others. They have small little clasping teeth as part of the clamps.
Old 03-17-2021, 07:28 PM
Mine clamps are like shark teeth so it does hold small bolts even if rounded. The problem is lack of room to stick the clamp in the positive side. After getting it in there, the bolt head is only about 1/4" sticking out for the clamp to hold onto. Got the new longer bolts, battery and its all fine now.
Old 03-17-2021, 07:32 PM
There ya go......
Old 03-17-2021, 07:34 PM
D idn't E arn I t
RANDY P's Avatar
What a pain. Left the lights on and killed my batteries over night. Jumping starting it with those side post little thing is a PITA. Ended up driving to Costco for new interstate batteries.
To make life hell.
Extra good times when you strip one of the terminals.
rjp
AOC/Hogg 2028
Old 03-17-2021, 07:53 PM
Neither way, they are too short
https://www.ebay.com/itm/Gold-GM-Side-Post-Battery-Terminal-W-Amp-Stud-Car-Audio-Power-Wire-Amp-Install-/201091299838
https://www.amazon.com/Audio-Power-Install-Battery-Terminal/dp/B00OVHCPD8
https://www.sonicelectronix.com/item-18129-JL-Audio-XB-SPTM-Side-Post-Battery-Terminal-Adaptors.html
I think you bought the wrong ones. Side post terminals can be MUCH better than top post, but you need the right type of connectors.
Old 03-18-2021, 12:34 AM
Yep, I bought the post extenders from the local auto parts house. They made it possible for a positive bite from the clamp in that small area. I my situation, there's no room between the battery terminal and the large fuse box. I have to cramp the clamp in there jsut to get it to bite. New batteries, and no more worries for some times until I leave lights on next time.
Old 03-18-2021, 12:57 AM
Kantry Member
oldE's Avatar
I got a smile out of this thread. When I had the old E (a 1969), the most suitable battery I could find locally was a side terminal battery, so I converted the ends of my battery cables and didn't worry any more about top posts shorting in the battery box.
Never had a corrosion problem. A bit of di-electric grease prevents that.
Best
Les
Best
Les
Old 03-18-2021, 03:36 AM
Zeke's Avatar
Best ever...
Old 03-18-2021, 06:57 AM
