I see you
Frost lines and footings
Here in NWNJ my frost line is 36". I'm considering pouring a pier for my telescope but 3 feet is alot of digging. I'm wondering would a spread footing one foot down measuring 1 x 1 x .5 feet be stable enough to avoid freeze thaw shifting.
The load would be approx 200 lbs. on the pier. thoughts?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Brew Master
Frostline is only a concern for heaving. If you're worried about the slab moving, rent a powered posthole auger, bore four six inch holes with rebar that extends above the holes, pour, then pour a slab over the four pillars. Me, I'd pour a 6" thick slab and call it a day if you're not worried about the slab moving during the winter.
Nick |
Thread Tools | |
Rate This Thread | |
