Still here
Critters chewing thru the wiring harness to the vent valve, yes.
I hate them too. Usually happen right as the annual NYS inspection is due, and the car won’t pass with it on. Clearing the code just before the visit doesn’t help either b/c the computer “knows” it was just cleared and must complete a few drive cycles.
So some $300 BMW secondary air pump or the like needs to be identified and swapped out before it can get inspected. I don’t mind addressing misfire codes but the gas cap stuff gets criminally expensive on an older car.
Ken 1986 930 2016 R1200RS |
Brew Master
Well! That didn't work. Light came back on this morning while idling in the driveway. Oh well, she's back at school. When she comes home next weekend I'll put it up on the lift and start checking things. I'll start with the fuse but I'd think if it's bad that it would have done it on the shakedown cruise I took yesterday.
Nick |
I was waiting for this post. That code description is a circuit fault code, the pcm , is either seeing an open circuit, short, or lack of power or ground . You will find your answer by pinning out voltages at the ecm, and component .
Welcome to my world .
No left turn un stoned |
Brew Master
As I understand it, the ECM tells the solenoid valve to close periodically. So how do I go about verifying voltage at the solenoid without a diagnostic tool that can send a command to cycle the solenoid?
Nick |
Fleabit peanut monkey
There is also the purge valve probably in the engine compartment. Solenoid on that can fritz. What size engine?
1981 911SC Targa |
Still here
P0466, yeah that’s gonna cost you extra, can you leave the car overnight ?
Still here
Vent valve circuit dude.
It says so in the description. First find the vent valve. Last edited by pmax; 04-05-2021 at 10:16 AM.. |
Yep yep. You are correct, Sir.
1981 911SC Targa |
Still here
Happens to be a path I have taken before, hence the critter reference, how the hell did they jump up couple feet ! Wrapped the replacement splice with black electrical overwrap in case it’s the color which caught their attention. But soldering while laying on your back was a new experience not to be repeated I hope.
Brew Master
4cyl 2.5L The valve I changed Is the one that goes into the intake. It's referred to as the vapor canister purge solenoid. From what I've found, there is also purge valve possibly back by the fuel tank at the charcoal canister.
Nick |
I'll look and see where it is.
1981 911SC Targa |
Brew Master
It looks like it's back at the charcoal canister by the fuel tank. I replaced the purge valve... not the vent valve. Friggin fraggin!
Nick Last edited by cabmandone; 04-05-2021 at 10:40 AM.. |
1981 911SC Targa Last edited by Bob Kontak; 04-05-2021 at 10:49 AM.. |
This is the purge solenoid. Suspect the one you replaced?
1981 911SC Targa |
Brew Master
Yep! I screwed the pooch! I searched vapor canister solenoid valve and the results only came up with the purge valve. I thought.. "must be the same thing!"... NOPE. Oh well. I found a vent valve for $58 shipped (Doorman) through ********* and another for $48 (Airtex) through stockwise auto. I'll probably order one. That way I have it on hand if there's nothing visibly wrong with the wiring.
Nick |
Still here
Make sure you put it in writing !!!
I think he just did.
I usually rig up a battery with wires under the car and put 12V to the valve. They usually never click because so often the problem. Ohm meter works too. Don't know the ohms but if you touch the terminals and it says a big "1." you are getting warmer.
1981 911SC Targa |
Brew Master
I watched a video on testing the solenoid. They just used a 9v battery but I have a way to put 12v to it.
Nick |
Still here
