Home of the Whopper
67 caddy loosing coolant
Preparing to pull the pimp mobile out of hibernation and noticed she was almost out of coolant.
I have had to top her up after every couple of rides, but not that much. Maybe a quart every 100 miles or so.
Figured head gasket but no white smoke from exhaust.
But now I had to add about a gallon and that was with zero miles driven but a few months of being parked.
She started right up with a little magic fluid and still no smoke.
No noticeable water on floor.
Any ideas on how to trouble shoot?
1967 Cadillac Convertible
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-09-2021, 02:10 PM
Hell Belcho
Nostril Cheese's Avatar
Id check the oil first, see if there is any coolant mixing. After that, a compression test to see if all is good.
Old 04-09-2021, 02:20 PM
Any signs of leaks while parked? It would be nice if its a leaking hose or other externals.
Cheers Richard
Old 04-09-2021, 02:35 PM
varmint's Avatar
Start fresh. I don’t remember a coolant flush as being that big a headache.
1971 R75/5
2003 R1100S
2013 Ural Patrol
2023 R18
Old 04-09-2021, 02:53 PM
Zeke's Avatar
Water pump bearing and seal are the usual go to look sees. Sometimes the water leaks but evaporates before making much of a puddle. When running it can easily evaporate off the block but should leave trails.
How's the cap? Are you using a pressure cap? The correct one? They aren't one-size-fits-all.
Old 04-09-2021, 03:53 PM
Do you have a coolant pressurizing pump? I'd start there.
Old 04-09-2021, 03:55 PM
wdfifteen's Avatar
It's on the floor or in the oil. But, was it really topped off when you parked it?
Old 04-09-2021, 04:03 PM
Home of the Whopper
Oil looks good and is a little low.
Nothing on the ground.
It may not have been topped off when parked, but it definitely wasn't a gallon low!
I checked before every ride cause I knew I was loosing coolant.
Even carry a jug with me.
I tried a pressure test and I cant remember the specifics, but I do remember it didn't help.
Somebody recommended a compression test.
I prefer leakdowns, but would compression be better?
Old 04-09-2021, 05:15 PM
Home of the Whopper
Original caps been replaced with a newer cap to allow a reservoir.
This change was made as one of the possible solutions of loosing coolant.
Odd thing here is loss of coolant without driving.
Old 04-09-2021, 05:18 PM
Home of the Whopper
Just read about a UV dye kit.
Think that's my next step.
Still thinking head gasket, but no smoke from exhaust and lost lots of coolant without engine running. And no hydro lock when starting after loosing so much coolant.
UV dye then go from there.
Car runs good so still plan on pimping all summer!!
Old 04-09-2021, 05:44 PM
Hell Belcho
Compression test would just give you a quick diagnosis if a head gasket is blown. Like $15 for a tester at HF. Leakdown testers are a bit more. Makes me wonder if the heater core may not have been filled up all the way to begin with. I have to imagine the core being bigger on a Caddy than the regular offering.
Old 04-09-2021, 05:50 PM
Home of the Whopper
Will google heater core.
I have leakdown and compression testers.
No problem doing both, or either one.
Which is preferred for my issue?
Old 04-09-2021, 06:03 PM
Fleabit peanut monkey
Bob Kontak's Avatar
As wd says, it's in the oil or on the floor.
If you are running water until you get the problem nailed then you know what I'm thinking. Seeping and evaporating.
I bought one of those ultraviolet kits from the Freight. Found a few problems with it.
I would do that and my money is on the water pump area given your oil is looking fine.
1981 911SC Targa
Old 04-09-2021, 06:14 PM
Hell Belcho
leakdown will be more precise, but take more time.
Old 04-09-2021, 06:28 PM
Hell Belcho
FYI...
a tool like this makes it a really simple job. I have the Airlift one, but there are others. Draws a vacuum on the system, which presents leaks in the system and also allows a complete fill with coolant..
Old 04-09-2021, 08:35 PM
wdfifteen's Avatar
Pump air into each cylinder with the leak down hose. You should be able to hear where the air is going. Bubbles in the radiator - head gasket. Before I loaned it out I had a cooling system pressure tester. You could pump it up to a few psi and watch for the leak. Or start the engine and pump it up and listen for a misfire.
Old 04-10-2021, 04:52 AM
This is the direction I would go. Pump it up, listen for a leak, or let it sit to see of it can hold pressure.
Old 04-10-2021, 05:25 AM
Senior Member
Superman's Avatar
I question whether water would move past a head gasket while the car is only sitting. No water in the oil means it's not going there. If there is no puddle on the floor, then it's either leaking slowly enough to evaporate or it's inside the car - heater core.
The first thing I think about when a car is losing coolant is water pump. They wear out. The impeller shaft just sits in a bushing, which wears. Conventional wisdom is that the water pump is one of the parts which should not be replaced with a rebuilt or remanufactured one. Brand new is the recommendation. Take your time and don't scratch the gasket surface.
Mocha 1978 911SC. "Coco"
Old 04-10-2021, 02:40 PM
Make Bruins Great Again
Por_sha911's Avatar
Turn on the defroster with the heat on. Leaking heater core sometimes shows up with fogged windshield and has that sweet coolant smell.
Pull the plugs and see if there is signs of coolant.
Pressurize the radiator cap and look for milk shake in the oil.
Joe
Old 04-10-2021, 03:59 PM
Hell Belcho
Any updates?
Old 04-13-2021, 12:56 AM
