Miata noise
Since you guys answer all my life questions, I actually have a car one. My sons 2001 Miata has a slight knocking when going straight. Stops when turning. Doesn’t matter whether in gear or not, accelerating, decelerating. Seems to appear as the car warmed up. Not at start up, but a few minutes in.
Thoughts? Thanks.
Old 04-10-2021, 09:12 AM
Slackerous Maximus
HardDrive's Avatar
Does it change with speed? First guess is wheel bearing.
2014 Cayman S, PDK
Old 04-10-2021, 09:18 AM
FUSHIGI
Is the noise more or less prominent when turning left or right? Long, sweeping turns (cloverleafs, roundabouts) may tell the tale.
Old 04-10-2021, 09:55 AM
fastfredracing's Avatar
Is the noise coming from the front or rear, or under you? Im with Harddrive . I have put a few wheel bearings on them over the years. Go straight down the road, then try to just barely turn one direction, then drift back the other way, your goal here is to try to shift weight to one wheel , then the other , then see if you can tell if the frequency of the noise changes . Usually, the faulty bearing will be on the side opposite of the direction you are steering when you hear it
No left turn un stoned
Old 04-10-2021, 10:04 AM
Goes away when turning left or right. Acceleration doesn’t matter. Car has 75k on it and seem a few track days. If I Jack the car up, will the wheel have a little play when I wiggle?
Old 04-10-2021, 12:10 PM
FUSHIGI
If so, there's your probable issue.
Old 04-10-2021, 01:11 PM
wdfifteen's Avatar
It might, but no wiggle doesn't mean a good bearing. Lots of good suggestions for you here at this Porsche message board.
Old 04-10-2021, 01:56 PM
Zeke's Avatar
Not at all familiar with a Miata but my '71 911 did that and it was a bad CV on the half shaft.
Old 04-10-2021, 04:06 PM
Bland
unclebilly's Avatar
Front hub / wheel bearing. These are a weak point in these cars.
Old 04-10-2021, 04:28 PM
Thanks everyone: I appreciate it.
Old 04-10-2021, 07:31 PM
Super Moderator
cstreit's Avatar
This is where I’d start. Then sway bar bushings, then cv joints.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-10-2021, 10:24 PM
Kraftwerk's Avatar
True the wheel bearings wear out super quick, so fast, an aftermarket bearing is available at a price, and is said to be much more robust. Everything in these cars is tiny - tiny so wear is inevitable, as is noise ..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 04-11-2021, 09:16 PM
Lots of snow Porsche away
after a good drive, if the wheel bearing is going the center of that wheel will be significantly hotter than the others. Easy way to diagnose a failing wheel bearing.
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 04-12-2021, 10:22 AM
mechanic by night
I have a 91 miata used for autocross and track days. Front wheel bearings are easy to replace. I have replaced several due to similiar symptoms. Pressed an old one apart and i could not find an issue.
Buy a spare or two. The last one i changed took less than 30 minutes.
76 911 "The Blond B_ch"
(what the wife calls it)
09 Mazda 3
06 subaru legacy spec B
91 track miata
Old 04-13-2021, 02:06 AM
