weekend wOrrier
That's what I'd want to see. If changing out the MC would cause the ABS to need a special treatment (or even bleeding the brakes), seems like there'd be a lot of post about it from those who had been there/done that to learn from.
Location: behind the redwood curtain, (humboldt county) california
classic bad mc after manual bleed - MC time
chris |
I had this happen on my 997 turbo. Master cylinder ran dry while bleeding the brakes and got air in the ABS. Felt like the MC was shot, as that was how it was acting, but no: the ABS needed to be bled.
You need to get a scan tool that has ABS bleeding for your vehicle. Don't throw parts at it until you do this first. The scan tool bleeding process typically requires a pressure bleeder to work as it will cycle the valves in the ABS to get the air out. Everything was back to normal on my car once I bled the ABS (with the tool). Good luck. |
Bland
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
In lieu of a scanner to perform an ABS bleed, you can go out and find a nice gravel road, or parking lot , and make several aggressive stops . The goal here is to initiate an ABS event, so that the pump comes on it opens and closes the valves in the HBCU.
Then come back, and try to re bleed. Worth a try before you have to go to a shop . The most likely scenario , is that you have air in the Hydraulic unit. Id at least want to try a proper bleed, with a scanner before I tossed a mc at it . If that does not work, then Id be looking at a master
No left turn un stoned Last edited by fastfredracing; 06-28-2021 at 07:02 AM.. |
Have the helper pump the pedal several times, then hold it down hard like in a panic stop. Open the bleeder screw with the helper holding the pedal down. If there is air, it'll come shooting out like crazy. Put a block under the pedal to keep it from going to the floor.
weekend wOrrier
I love this place. A week ago, I had no idea changing the fluid/ over compressing the pedal could cause MC problems. I also didn't know the ABS systems could potentially require extra love if they got bled dry. Now- not only do I know that, I know I need to go skidding on a dirt road to fix the ABS! Get em' duke boys! Yee Haw!!!!
Now in 993 land ...
Hi Guys,
Believe it or not, but after driving for a while it seems to have gotten better. I want to emphasize that it takes a lot of force to make it budge, really have to stand on it. A smaller person would not even be able to get it to compress. So the truck certainly is driveable but of course I can't keep it this way long term. The gravel road is a really good idea and I was wondering about that. I'll give that a shot and then try to bleed again. Maybe just a series of bleeds and driving will get it ironed out. Great input on the ABS unit and MCs etc. I'll update the thread with how things progress. Thanks a ton! G |
You do not have permissi
Meanwhile other things are still happening. |
Now in 993 land ...
John,
Any recommendations for a scan tool? Looks like the cheaper scan tools have these functions. Thanks! Georg |
Something to check, are your brakes assisted by the power steering pump? Most diesels are, if so there is a hydraulic accumulator located near the master cylinder that can fail, it gives symptoms similar to what you are describing.
87 930, |
Now in 993 land ...
It looks like a regular brake booster. This is a 1500 with the Ecodiesel, so a while a diesel, a different animal! Thanks!
G |
Now in 993 land ...
I ended up buying this tool to perform ABS bleeding procedure:
https://www.amazon.com/gp/product/B07XK1P8ZT It did the job nicely in terms of walking me through it and we repeated it a few times on every axle. Then bled it all again, no bubbles anywhere and of course, the pedal still feels the same. I have to stand on it like an ox to cause it to sink, so it isn't a safety issue but it bugs me. I have a bunch of recall work scheduled at the dealer in a few weeks and I'll see if they bite on putting a new MC in for me under my extended bumper to bumper warranty. If not, that will be my next project on this when I get around to it. Thanks for all the input. I sure learned a lot and now am invested another 180 into the truck. ![]() G Last edited by aigel; 07-22-2021 at 09:29 PM.. |
Gon fix it with me hammer
huh? thought issue was sinking pedal, eg soft?
but you call it super stiff now?? any missing helper springs on the pedal box?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Sinking pedal almost certainly means a small leak (bypassing) in the master in my experience. It won't get better.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
When the pedal is pushed fully to the floor: -The piston/seal in the master cylinder bore travels to the end of the normally unused cylinder section. -This section will be corroded and lumpy with rust after a decade or two. -That action can break the high pressure M/C old rubber seal, resulting in a permanent sinking peddle with loss of brake pressure. FWIW, the M/C reservoir gravity port and system is closed off with only an inch or two of pedal travel. Sealed system then.
Meanwhile other things are still happening. Last edited by john70t; 07-23-2021 at 09:10 AM.. |
