burn pile over septic drain field
The PO of our house had a burn pile (for tree limbs, garbage, whatever). It's in a spot that the missus doesn't like. She wants to move it. Where she wants to move it is right over the top of the drain field. To me this seems like a bad idea (essentially having a bonfire over the top of the drain field).
This isn't a great representation, but you can definitely see the old burn pile. ![]() Maybe this is better. The amber spot is the old burn pile, and the red spot is where the missus wants to put the new burn pile. The blue line is roughly the path of the drain field (yes, it's a single line, it doesn't branch out.) ![]() My other problem is that the new location that she wants to use is farther from our hose bibs.
I think being within range of garden hose if fire gets out of hand is higher priority than location over leach field . Having said that I wouldn't put it over the leach field/line either . Do you actually use a burn pile ?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I see you
What harm could it do to the leach field?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I would be worried about the fine ash and sediment leaching its way down in there and clogging it up .
My thought is why take the chance ? I had to dig mine up under the cover of darkness 5 years ago. That is a job I hope to never do again , or pay for .
No left turn un stoned |
I don't know. How deep is it? I know a big fire can get hot enough to melt aluminum cans and glass bottles, and the ashes in a burn pile can be hot for a couple of days after a fire. How deep is a leach field? Right, I don't want to have any issues with the septic system.
Brew Master
Around here it wouldn't worry me much with an older system due to the depth of the tile. If you know how deep your outlet is on your septic tank, you have a "pretty good" idea how deep your field is because it has to be roughly the same depth as the tank outlet.
Nick |
I have no idea how deep the outlet is. That's a big part of the problem.
Information Overloader
Calmly and quietly ‘splain to the missus that she doesn’t want a stinky expensive surprise. Show her the general location of the drain field and say, with your administrative voice, ‘Not here, honey bunch’.
But unless you have a roaring, atomic conflagration over several days (or on a peat bog) the field will be oK. |
You do not have permissi
In proximity of hose, away from house and trees, downwind. That would be my guess.
Meanwhile other things are still happening. |
What I'd told her was I don't want to have a roaring fire over the leach field. I'd hate to damage something. She said something to the effect of "if you damage a pipe, couldn't you just replace the pipe?" I would rather be safe than sorry. I've already had to deal with one backup, and it was unpleasant to say the least.
Banned
is the drain pipe clay or PVC
older stuff is more likely clay up to the 50's LIKE MOST PLASTIC PVC will ''melt'' deform from heat and can collapse and block flow fired clay pipe is not effected by open fire on the surface |
How about the other side of the shed. Away from the pipe and away from the shed. And that way you don't have to see the pile of ash all the time.
We burn a lot of stuff, big piles twice a year, including neighbors stuff. I have done the landfill versus burning math with the county folks.
1996 FJ80. |
esp if it's one like this.....
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
cant you move the red dot 15-20 feet to the right?
i always thought the earth was the ultimate insulator. i was told that anywhere on earth, five feet down, the ground is 58 deg. not sure that was some old dude lying to my ass, but i liked it.
poof! gone |
that is a lot of poo and pee!!!
i dont know jackS about septic stuff. is that a big system?
poof! gone |
Doesn’t decomposition of waste produce methane? That fire could be hotter and last longer than planned.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Banned
I have seen the components for a leach field at Menards...plastic and half-moon shaped. Apparently they just lay them on top the the sand/gravel and then cover them up.
I think the deal is this, we've got a small stone circle that can be used for something like a camp fire, and we have (had) a big spot for a burn pile. For some reason, I think she's trying to combine the two, but they need to be separate (radically different sized fires). Quote:
I suspect ours isn't that neat and tidy. It's probably more like the country "this'll do" version. Quote:
I'm just not sure how deep the leach field "stuff" is. If the pipe is 2-3' down, it's probably not a big deal. If it's 1' down, then I wouldn't want to risk it. Maybe what I need to do is get the missus to have the camp fire in one place and the burn pit (bonfire) someplace else.
