my new blow dryer sucks
I shower both at night and morning. Without a shower, I can't sleep but hate sleeping with wet hair. Finally my blow dryer gave up the ghost. Went to Target and bought another only to discovered this thing will not blow hot hair continuously. It cycles between the hot and cool air every 20 seconds or so. WTF. Drives me nuts. Too many lawyers? Must go back and see about getting anther that will not cycle like that. This is like the factory setting in the shower control vales. Its preset at factory to lukewarm at full hot so the user wouldn't get burn. Fooking BS.
Porsche Design has been making hair driers since 1939. The best ones are the models that have a fan speed of 1.3 revolutions to 1 of the armature. The fan is driven via belt with no cycling or shutdown due to thermostat interrupt. They are quite a blast of air.
Most models were Fooking equipped until later years. Factory settings seemed to like the mid range and higher speeds for spirited styling. Oddly most models shared a special smell after use that has been described as something like mohair and motor oil cologne which seemed to linger for decades. These hair driers have been known to keep people up at night.
Jeff Hail "All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible" |
ha.
Brew Master
The easy solution is to shave your head. No more hair dryer needed!
Your blow dryer sucks? Does your vacuum blow?
Garage Queen
I have not seen that kind of setting but most if not all hairdryers come with a cooling option now because research has shown the cool setting reduces frizz by allowing the hair shaft to lay flat.
My suggestion: return it and try another. I know: put that on the list of things you never thought you would read about here.
Stephanie '21 Model S Plaid, '21 Model 3 Performance '13 Focus ST, Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3, Last edited by PorscheGAL; 08-14-2021 at 04:44 AM.. |
I see you
Oh you people with your modern problems. Of course I can't really relate as per my avatar.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Model Citizen
I think look171 needs an avatar.
Daniel Oss from Bora
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Well you do have to turn it around then...
Humble brag hair-boy.
![]() I’m a towel away from a dry head. A face towel will suffice
poof! gone |
I didn't know men still used blow driers (since disco and long hair went out of fashion in the 80s). Too much work for such limited return. Just get a short hair cut and it dries almost instantly...on its own.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Platinum Member
Look - don't you have a heat gun in the shop?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
My wife has a Dyson. Seriously expensive, but worth it...
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
One of my buddies has a flat top. He has had the same haircut style since the 1960s. He has never used shampoo or a blow dryer. Just the same bar soap for head and body. Towel dry, his hair sticks straight up.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Control Group
Daniel Oss is balding
Crew cut is perfect, but the wife gets a little bent when my curly locks are shorn Last edited by Tobra; 08-16-2021 at 08:45 AM.. |
My wife has one also and says the same thing. She loves it.
I have no hair so I have no wet hair issues. Maybe Look should shave his head and forget the wet hair.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
I can’t believe there is a thread on blow dryers and I’m about to contribute to one, but I absolutely love my Harry Josh dryer. Expensive but well worth it.
roadster + speed
