LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Burning Ring of Fire!
Thunderstorms here twice in the last week...lots of limbs down. Power out for 4 days between the 2 storms.
Cut the limbs up and made a pile.
Today...no wind...green grass...perfect for burning the pile.
Had about a quart of drain oil, which I mixed about a quart of gasoline with it. The limbs hadn't dried good, so I knew I needed some help getting it started.
The pile was over head high. I stuffed some paper in the bottom and poured the mixture over the whole works....and lit a match.....
My mistake was waiting too long to strike the match...the fumes spread out way beyond the pile.
90 degrees out...I was wearing shorts. I no longer have leg hair!
Other than that...I'm fine.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 11:16 AM
I sure hope you have video of it!
Old 08-26-2021, 11:19 AM
Well.... at least ya picked a good day to put on some shorts!
Could've been much worse
Old 08-26-2021, 11:23 AM
Never use gas. I’ve seen the boom!! Diesel in a Hudson sprayer.
Old 08-26-2021, 11:31 AM
Yeah, that's a big NO NO on the gasoline part of this equation. The fumes will ignite way before it ever reaches the pile of limbs/paper/oil.
Old 08-26-2021, 11:36 AM
I figured a 50/50 mixture w/drain oil would eliminate the danger.
I shook it up good before pouring it on also!
Plus...the 90 degree temp today didn't help either.
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 11:41 AM
Old 08-26-2021, 11:55 AM
One of my buddies can tell a great story of when he was a kid. His dad wanted to just burn the leaves from the heavily wooded house the live at. His dad had a 55 gallon drum and welded up a grate to hold the leaves off the ground and let air in. He figured once they were burning, just keep tossing in leaves. Of course the leaves were a little wet from dew, so his dad pours on some gas the throws matches in. Nothing. More gas, still nothing. More gas one more tossed in match and my buddy said next thing he knows is he is laying on his back next to his dad, his ears are ringing and there is a volcano of burning leaves erupting from the barrel. His dad jumped up and started yelling to stamp out the falling leaves that are on fire. He can't hear his dad due to the ringing in his ears, but he figured he better help put of the fires before the neighborhood has a forest fire.
They put out all the leaves, and neither of them were hurt. He said his dad came to his room that evening when he could hear and said we will never speak of this day again.
Old 08-26-2021, 12:22 PM
Control Group
Tobra's Avatar
This
Old 08-26-2021, 12:25 PM
^^^ It was mixed with drain oil....just not enough drain oil.
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 12:28 PM
id10t's Avatar
When I worked in the PT department of an acute care hospital, I worked on a guy w/ burnt legs (mostly 2nd some 3rd).
He had a brush pile, put some diesel on it, but lit it standing in a shallow dip in the ground that was downhill from the brush. Filled with diesel fumes, it went "woosh" around his legs.
Worked on another guy, he was working in the engine bay of his boat wearing a speedo, something went "woosh" and he had 2nd degree over most of his body.
Things I never fark around with are flammable gasses and electricity.
The Unsettler
stomachmonkey's Avatar
Thought this was gonna be about Hemorrhoids
"I want my two dollars"
"Brandon Won"
Old 08-26-2021, 03:37 PM
Bill Douglas's Avatar
We have a pizza around here called the Burning Ring of Fire.
Yup.
Old 08-26-2021, 03:50 PM
Be careful with the size of the pile also. Years ago I had a very large pile of limbs and brush to burn. I thought to myself, "Wow, this pile is pretty big." I lit the thing off, and soon had to back away because of the radiant heat. I had a black, heavy duty garden hose with a spray nozzle on the ground maybe 25+ ft. away in case I needed it. My wife said, "Look at the hose.' I looked and it had water squirting out if it in three places from the radiant heat weakening the hose so the water pressure could burst through. Learned a lesson that day.
Marv Evans
'69 911E
Old 08-26-2021, 03:52 PM
No...I was wearing shorts and underwear.
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 03:58 PM
A930Rocket's Avatar
no...i was wearing shorts and underwear…until they burned up.
fify
Old 08-26-2021, 04:40 PM
The 'Ka-Woosh' was enough to make the turtles hit the water.
98 Honda Prelude
22 Honda Civic SI
Old 08-26-2021, 05:33 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Yup.
I sometimes get that after Pizza, especially if it's the Pizza My Heart, 40 garlic clove...
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-26-2021, 05:53 PM
I see you
flatbutt's Avatar
BTDT too. I imagine that the oil would have resulted in a serious column of smoke.
Old 08-26-2021, 06:17 PM
Originally Posted by 70SATMan View Post
Pizza My Hear.
I just googled that. Wow, I'd risk a burning ring of fire for that pizza!
Old 08-26-2021, 06:51 PM
