Shaun @ Tru6's Avatar
Stereo has developed a crackle
I have a B&K Components AVR 307 for the shop. It is insanely loud and clear at the same time. And often is. It developed a crackle a week ago. Swapped speakers, it's the stereo.
Is there a typical component in a stereo that when it goes bad creates a crackle? Probably not worth having it repaired as they are $300 or so on eBay.
Tru6 Restoration & Design
Old 09-20-2021, 01:58 PM
craigster59's Avatar
I had that problem on a Sansui receiver. Sprayed the volume knob with contact cleaner and it did the trick.
https://www.amazon.com/Hosa-D5S-6-DeoxIT-Contact-Cleaner/dp/B00006LVEU/ref=sr_1_5?dchild=1&keywords=electronic+cleaner+spray&qid=1632172261&sr=8-5
Old 09-20-2021, 02:13 PM
gwmac's Avatar
yup
cables switches and controls first things to check
Old 09-20-2021, 02:26 PM
scotricker's Avatar
that's it . The knobs are ancient analog potentiometers that get gritty.
First, turn it off, ask me how I know,
then quickly, briskly, turn the volume all the way up and down a few times to clean off the wire coil.
Do the same with balance, bass, treble,
My old old Pioneer that I love is still crankin out the tunes in my garage
good luck,
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 09-20-2021, 02:30 PM
Edministrator
Steve Carlton's Avatar
Or just play Neil Diamond from here on out.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 09-20-2021, 02:38 PM
scotricker's Avatar
ok, this guy = winner
Scot
Old 09-20-2021, 02:40 PM
Get a can of deoxit for the pots.
1982 911 Targa, 3.0L ROW with Webers
Old 09-20-2021, 02:41 PM
I see you
flatbutt's Avatar
another vote for dirty pots.
Old 09-20-2021, 02:43 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
is it crackling while turning knobs (you didn’t say)? yes = do the above
or does it just start crackling on its own? if yes = something else is going on. take it to repair man. most repairs are about $75 in my experience
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 09-20-2021, 03:13 PM
I've got a can of Deoxit somewhere around here but dang if I can find it now. If I could I'd take a picture of it for you Shaun.
Scott
'78 SC mit Sportomatic - Sold
Old 09-20-2021, 03:27 PM
It's in the Amazon link above. Even stationary knobs will crackle while stationary.
Great, now I've got "Cracklin' Rosie" running through my head....
Old 09-20-2021, 03:30 PM
Edministrator
My job is done.
O - $1
O - $2
O - $3
Old 09-20-2021, 03:32 PM
I think I bought this stuff instead of Deoxit, as it is pretty harsh if I recall.
This says it's safe on plastics.
Scott
Old 09-20-2021, 03:37 PM
My job is done.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-20-2021, 03:41 PM
Edministrator
But wait- there's more!
O - $1
O - $2
O - $3
Old 09-20-2021, 03:48 PM
Fleabit peanut monkey
Bob Kontak's Avatar
WD40 works fine.
1981 911SC Targa
Old 09-20-2021, 03:56 PM
Wow, thanks for all the great info. It's at a friend's house now, he decided he didn't want to mess with. Will get it this weekend and use all the good advice.
I did mount it about 9 feet high so it wouldn't get so much dust and debris and almost certainly sanded aluminum dust in it. If I can get it working, I'll put some sort of case around it to protect it better.
Old 09-20-2021, 04:51 PM
908/930's Avatar
You did not say if it makes this noise at random or when adjusting the volume? As mentioned try cleaning the volume pot if that does not work it could be one of the DC power supply capacitors, also a pretty easy fix if you can get to them. It has multi channels do they all make the noise?
Old 09-20-2021, 05:17 PM
Senior Member
Superman's Avatar
Even if the crackling does not occur when the knobs/switches are being moved, we cannot rule out dirty pots and switches. DeOxit has solve many mysterious problems with my electronics. Some sheet metal cover will likely need to be removed to access the contact portions of the pots and switches. Only a TINY amount of DeOxit is needed on each component. Such a small amount that it is very difficult to get only that small amount to come out of the can. Then work the pot/switch for a few seconds.
Mocha 1978 911SC. "Coco"
Old 09-20-2021, 05:24 PM
It makes noise all the time. I'm only using 2 channels. I had thought of using others to see what would happen but my friend said to bring it over. then to pick it up.
Old 09-20-2021, 05:58 PM
